Closed Thread
  #41
Old 03-17-2016, 03:08 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Default Let it begin....
I've waited long enough.....
Maybe too long?
That is THE DIRTIEST OIL I have ever seen.
Less than 5 hours with this oil.
Custom Oil Drain Pan.
  #42
Old 03-17-2016, 06:09 PM
Jrgunn5150's Avatar
Jrgunn5150 Jrgunn5150 is offline
Rudderless
You're lucky, you have tons of room there, my driven clutch is resting against my stupid brake disc.
  #43
Old 03-18-2016, 02:57 AM
bob58o's Avatar
Quote:
There is lots of room. The engine looks small back there.
The guy who sold it to me said after a few months I'd want a bigger engine (when I showed him the 212cc). I don't think he thought it would perform as it does, but he was also correct. (Maybe he knew I was nuts?)
I was considering upgrading to a 420 or adding a second 212, but having nothing else to put this on, I decided to keep working on this engine.
Should call this thread "How to throw a billion dollars at a $99 Chinese air pump
  #44
Old 03-18-2016, 01:11 PM
bob58o's Avatar
Sh#tty click torque wrenches. 30 bucks for all 3! Lifetime warranty. Mixed reviews.
Is Doc Sprocket a real Dr??? I need help. The hemorrhaging doesn't stop. Lol
  #45
Old 03-18-2016, 01:38 PM
landuse's Avatar
landuse landuse is offline
I wish doc was still around
  #46
Old 03-18-2016, 01:49 PM
bob58o's Avatar
Quote:
Now I feel bad, I hope you just mean Doc is no longer around the forum?
Searching the threads on here I saw his name often
  #47
Old 03-18-2016, 02:47 PM
bob58o's Avatar
First attempt at reading a spark plug. The last video I posted was the last time the engine ran.
Looks clean. Too clean, too lean?
Also sometimes likes to decel backfire.
I've been running with no muffler... I've been told this may be bad for the exhaust valve (back pressure.... Whole new thread, lol)
Looks like both jets may be need to opened up if I stay with this carb, but will probably upgrade header and carb
  #48
Old 03-18-2016, 02:48 PM
bob58o's Avatar
Another
  #49
Old 03-18-2016, 06:08 PM
Jrgunn5150's Avatar
Rudderless
That plug looks pretty perfect.
Mine back fires too, it's pretty sweet,
https://youtu.be/3yureTt7AHE
The Following User Says Thank You to Jrgunn5150 For This Useful Post:
bob58o (03-18-2016)
  #50
Old 03-19-2016, 03:20 PM
bob58o's Avatar
Some pics and measurements
Guesstimate measurement on venturi around 22mm but I'm going to double check all these.
  #51
Old 03-19-2016, 03:22 PM
bob58o's Avatar
Rockers, springs, head bolts, valve cover gasket...
  #52
Old 03-19-2016, 06:20 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Doc gets around once in a long while. He has been busy with family.
Why don't you, go back to your double wide and fry something!
The Following User Says Thank You to chancer For This Useful Post:
bob58o (03-19-2016)
  #53
Old 03-22-2016, 03:40 AM
bob58o's Avatar
Tuesday is my only day off so I have set a goal.
"Off with the Head!"
  #54
Old 03-22-2016, 09:10 AM
bob58o's Avatar
Some pics of Combustion Chamber, Valves, Ports, Retainers, Lash Caps, Springs,...........
  #55
Old 03-22-2016, 09:13 AM
bob58o's Avatar
More pics....
  #56
Old 03-22-2016, 09:23 AM
bob58o's Avatar
More
  #57
Old 03-22-2016, 10:58 AM
bob58o's Avatar
I measured the Piston to Deck Height to be > 0.020" at TDC. It was probably 0.021" or 0.022" in the hole according to straight edge and feeler gauge. A +0.020 ConRod will get me close to flush with no Pop Out. A 0.036" Multi-Layer Steel Gasket should give me the clearances I need plus some. I'm going to check everything with clay once I get the TC and side cover off and install the Black Mamba Jr Camshaft, but first want to work on Porting and Polishing the Head.
---------- Post added at 11:41 AM ---------- Previous post was at 11:05 AM ----------
Just got off the phone ARC Racing and ordered the following parts.
If you wanted 25mm SS exhaust valve for your Predator but saw it was "Out of Stock," I handled that for you. It is now available on the site.
DJ-1310P-36 Predator Head Gasket .036 70mm
1 $14.95 $14.95
DJ-1127 Int. Valve; Stainless 27mm HP
1 $14.73 $14.73
DJ-1121 Stainless Steel Intake Valve 25mm
1 $14.73 $14.73
DJ-1047 Retainer, Kit Valve HD w/ Keeper
2 $9.50 $19.00
DJ-1051 High Performance Lash Cap
2 $4.16 $8.32
6256 Billet Rod, HF Predator +.020 3.328
1 $83.95 $83.95
$12 Shipping
Stock Piston
Stock Lifters
Stock Pushrods
Stock Rockers
Stock Crank
Stock Flywheel
It All Adds up Quick! I'm hoping all this extra power (from new cam, rod, gasket, port, and polish) will allow me to run an alternator from the axle. (That will be another chunk of change, but will allow me to save some loot and get smaller battery - But that's in another thread.)
---------- Post added at 11:47 AM ---------- Previous post was at 11:41 AM ----------
By the Way... ARC Racing has awesome Customer Service! Every single time I Call, I get pleasant gentlemen with a Southern Accent who is always willing to talk me through stuff!
Tip of the Cap to Customer Service at ARC RACING
---------- Post added at 11:58 AM ---------- Previous post was at 11:47 AM ----------
ANY HELP WOULD BE USEFUL!
Since this is my fist look inside the combustion chamber, I don't know what normal looks like. The intake valve is much blacker (more Carbon?) than the Exhaust Valve. I don't know what this means or if it is normal?
Intake lash was set to 0.002 and exhaust 0.003"
I'm going to start looking how to clean up the piston and combustion chamber, but please share tips if you got them.
Then on to porting and polishing. I think I will be OK. It doesn't look too bad. I might not even try the carbide burrs unless I find the cartridges are too slow.
  #58
Old 03-22-2016, 11:21 AM
bob58o's Avatar
Soooo Excited!!!!
  #59
Old 03-25-2016, 12:46 PM
bob58o's Avatar
Not sure if my addiction is engine related or spending related???
More Goodies.....
GX 390 Carb
http://www.everestpartssupplies.com/...h-free-gaskets
GX 390 Carb to Predator 212 Adapter
http://www.arcracing.com/6878-arc-ca...x390-to-gx200/
GX 340/390 Air Filter Adapter
http://www.arcracing.com/6929-arc-gx...ilter-adapter/
Fuel Pump
http://www.arcracing.com/6935-fuel-pump-mikuni/
  #60
Old 03-25-2016, 02:27 PM
Jrgunn5150's Avatar
Rudderless
Lol, you're on a tear.
Closed Thread
