Go Back   DIY Go Kart Forum > Announcements & Suggestions > FAQ & Articles
Closed Thread
Old 04-20-2015, 08:55 AM
KartFab's Avatar
KartFab KartFab is offline
Default How to Assemble A Roller Chain Master Link
This short article will show you how to install a roller chain master link and orient the retaining clip correctly. This is for your standard go kart roller chain (non-o-ring).
  1. Line up the chain ends on the axle sprocket.
  2. Install the plate with pins so the grooves in the pin ends are facing outward
  3. Install the non-pin plate
  4. Using a screwdriver, put pressure on the retaining clip so it snaps into the pin grooves. The closed end of the retaining clip should lead and the open end should trail as the chain travels around the sprockets (see video).
This is part of my grand scheme to make a little website, and I figured I would share it wherever I can to help out those that may need to assemble a master link on roller chain.
go-kart-master-link-clip-1024x768.jpg   installing-go-kart-master-link-clip-1024x768.jpg
Free Go Kart Plans https://kartfab.com Go Kart Videos https://www.youtube.com/c/KartFab
The Following User Says Thank You to KartFab For This Useful Post:
2SlickNick (04-21-2015)
Old 04-20-2015, 06:32 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Its the little things that make the big difference. Who knew it mattered which way the retainer went. but it does. Thanks for getting this info out there. cant wait to see the website.
Why don't you, go back to your double wide and fry something!
Old 04-20-2015, 06:44 PM
Russ2251's Avatar
Russ2251 Russ2251 is online now
Suspension? Not a GoKart!
Comes with experience.
Once it is known for certain what chain length is needed I eliminate the master link completely.
An endless loop.
https://www.youtube.com/watch?v=c4jch0puM1A
The Following User Says Thank You to Russ2251 For This Useful Post:
Poboy kartman (04-20-2015)
Old 04-20-2015, 06:47 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
Actually I just learned that last week when a member told a noob. That is why I like the idea of his videos, threads, and upcoming website. Put all the little hints in one place rather than searching all of utube and this forum.
Old 04-21-2015, 12:33 AM
landuse's Avatar
landuse landuse is offline
Awesome website kartfab!
Old 04-21-2015, 12:59 AM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
Nice!
I have been putting a dab of JB weld on my retAinter clip lately. Just for my own peace of mind, ever since I got stranded with chain popping off at the master link once.
https://www.youtube.com/user/dirtyinaz
  #7
Old 04-21-2015, 01:51 AM
ResetBTTN ResetBTTN is offline
Junior Member
Good post. I've always known closed end is the direction of travel....and needle nose pliers are my on and off tool.
  #8
Old 04-21-2015, 02:13 AM
BirdFanatic BirdFanatic is offline
Now all you have to do is make an easy video of taking the pins out of the chain without a chain breaker the old fashioned way with a vise,hammer and pic or small screw driver.
@@Caution burns rubber often
Closed Thread
