Closed Thread
Old 12-09-2014, 03:30 PM
NapalmicAcid NapalmicAcid is offline
Default Engine broke?
I was riding down the road with my 6 HP tecumseh engine and suddenly the engine started making a clicking sound and then just stopped. Now when i try to pull the pull cord to start it all i get is click-click-click. What could this be?
Old 12-09-2014, 03:55 PM
BirdFanatic BirdFanatic is offline
Quote:
There could be a problem with the rocker arms falling off or a rod fell loose (not the rod that attaches to the piston).When i had my 6hp power sport the rocker arm came off the rod .
@@Caution burns rubber often
Old 12-09-2014, 03:57 PM
Quote:
Wish I knew what any of that meant! I will probably take it to a small engine repair shop and let them see it. Thanks though!
Old 12-09-2014, 04:09 PM
ML-TOYS's Avatar
ML-TOYS ML-TOYS is offline
Ok so if you dont intend on finding the problem and fixing it yourself then why ask what it could be.
Old 12-09-2014, 05:00 PM
Quote:
Well I agree. I can't afford to take it to a repair shop anyways. Could it be the spark plug?
Old 12-09-2014, 05:01 PM
Could you go into more detail on what you mean? I am a "newb" at this.
  #7
Old 12-09-2014, 05:14 PM
http://forums2.gardenweb.com/forums/...721014.html?52
That could be your tapping sound the rods sometimes fall off the cam and down into the crank case pop off the valve cover and take a look maybe take a picture
  #8
Old 12-09-2014, 06:24 PM
OzFab's Avatar
OzFab OzFab is offline
Unfortunately, that would be a best case scenario... worst case is you snapped a conrod...
Sounds like it's time to get your hands dirty; rip into it & let's find out what happened...
Question 1. When you pull the starter rope, does it have the "usual" resistance?
  #9
Old 12-09-2014, 07:26 PM
It has a considerably (maybe just slightly) ease of pull. Still requires some force
  #10
Old 12-09-2014, 07:30 PM
Is the crank case the entire metal side (the side the clutch is attached to?)
  #11
Old 12-09-2014, 07:33 PM
ML-TOYS's Avatar
Post a pic of both sides of your engine so you can get instructions on how to get into it.
  #12
Old 12-09-2014, 08:20 PM
could it be blew a hole in the engine making it tick loud
  #13
Old 12-09-2014, 08:26 PM
thebroketeenager thebroketeenager is offline
Default Loose valve?
Judging off of this, your connecting rod isn't broken. Like the many before me, it's likely a valvetrain problem. When was the last time you checked the valve lash? Loose valves could have easily caused the rocker arms to go places they're not supposed to. Right now I can't think of anything else that could be realistically your problem, but I'll keep thinking.
  #14
Old 12-09-2014, 08:27 PM
Xtreme Yard Karts's Avatar
Xtreme Yard Karts Xtreme Yard Karts is offline
The first thing to do is pull the plug and check to see if you see the piston is coming up and down with a light through the spark plug hole. If not, it is a broken rod.
If you can see the piston moving, pull the valve cover on top (square cover with OHV stamped into it) and check to see both the rocker arms are intact. If you get to this point, come back and we'll tell you how to fix that!
  #15
Old 12-09-2014, 08:37 PM
Quote:
Well to be honest I have no idea what the valveTrain is or anything about that!
  #16
Old 12-09-2014, 08:49 PM
When I pull the start the engine while looking through the spark plug hole I see something coming up and down. Here are some pics (if they didn't load I'll post them soon)
  #17
Old 12-09-2014, 09:12 PM
Heres the pics
  #18
Old 12-09-2014, 09:23 PM
ML-TOYS's Avatar
The top of this valve spring does not look right. Like the big washer ring is gone or something. Thats a guess since i havent opened one up in a while.
The Following User Says Thank You to ML-TOYS For This Useful Post:
BirdFanatic (12-09-2014)
  #19
Old 12-09-2014, 09:29 PM
When you pull the cord, do the rocker arms move?
  #20
I see what you mean. When I check it out tomorrow I'll investigate some more. Could that actually be causing all these problems though?
On anther note, I am having some serious trouble getting the **** clutch off! I undid my set screws and bolts and it won't budge. Can't be related I don't believe just a grumpy clutch.
I'll get back with y'all tomorrow
Closed Thread
