Closed Thread
  #41
Old 11-02-2008, 07:23 AM
crazycart's Avatar
crazycart crazycart is offline
RedNek Engineering
A governor does not make a engine run at WOT....
For some there is therapy...For me there is motorcycles...
  #42
Old 11-02-2008, 08:50 AM
iwanttogofast iwanttogofast is offline
noob question whats WOT? also does govenors even run all the time or does it engage after a certain rpm like a clutch?
  #43
Old 11-02-2008, 09:05 AM
Russ2251's Avatar
Russ2251 Russ2251 is offline
Suspension? Not a GoKart!
WOT= Wide Open Throttle
Governor is always active.
https://www.youtube.com/watch?v=pzrp0eki0Fo
  #44
Old 11-02-2008, 09:09 AM
Thank you, i swear i learn 100 new things every day on here.
  #45
Old 11-02-2008, 10:18 AM
tenlizard tenlizard is offline
ok when i try to make my engine idle it doesn't work it seems like it's going 5000 rpm. whenever i adjust the butterfly nothing changes also when i play with a screw that has a spring on it on the side of the carb it makes it go faster/slower. i thought this was supposed to be the butterfly's job not the screw
Wigster
  #46
Old 11-02-2008, 10:48 AM
i'm going to put on a video for help in about 10 minutes
Wigster
  #47
Old 11-02-2008, 11:33 AM
never mind i just got it to work and i figured out what the problem was
Wigster
  #48
Old 11-02-2008, 11:48 AM
i definately need to remove the governor because it's screwed up and this is a really old engine anyway. the governer keeps on idle making the butterfly go up and down causing the engine to surge. should i remove the governor?
Wigster
  #49
Old 11-02-2008, 11:59 AM
yes http://www.affordablegokarts.com/govenor-removal.php i know it may not be your engine but same principle. and the screw with the spring is to richen or lean out your engine. Used for idle and when you take off. like if you take off and it bogs down its either lean or rich not really sure wich one but you can mess around with it and get it to were it idles fine and to were it has a good reaction time.
  #50
Old 11-02-2008, 05:58 PM
my go kart that is waiting for the engine has a 72 tooth sprocket. the kart is 100lbs not including engine. how many tooth clutch should i use? 11 or 12? oh and i'm 200lbs
Wigster
  #51
Old 11-02-2008, 06:42 PM
not sure wat you want to do with it like off road on road?
  #52
Old 11-02-2008, 07:14 PM
both but the off road is completely flat i live in the lowcountry
mostly on-road probably
Wigster
  #53
Old 11-02-2008, 07:20 PM
the shaft is 5/8" and the tires are 14.8" on 6" rims
Wigster
  #54
Old 11-03-2008, 01:59 PM
with a 72 just use like a 12 tooth cluth that would be fine.
  #55
Old 11-03-2008, 04:24 PM
today i set up the throttle on the engine, removed the pneumatic governor, cleaned out the gas tank, removed carbon deposits from cylinder head, piston, and valves.
now i have to put in new oil, get and install a new ignition solid state armature, and clean the carburetor, get a clutch, and get a exhaust system.
my ignition armature has breaker points.
it's a very old style ignition armature.
it doesn't have a boot to attach to the spark plug lead, just a circular piece of metal.
if your hand get's close to that metal it releases a painful shock which is hazardous. also the newer ignition armatures are simpler in design.
this engine had a different kind of governor
it had a pneumatic governor as opposed to a mechanical governor. it was easy to take off. i used the governor spring to make the throttle.
currently the engine is separated from the gas tank and the carburetor.
i think i still need to lap the valves
by doing research, i know this engine was made earlier than 1983
Wigster
  #56
Old 11-03-2008, 04:30 PM
Russ2251's Avatar
Smaller displacement engines use air vane governors.
Not sure, but may have to match flywheel to new ignition.
  #57
Old 11-03-2008, 05:28 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
As long as its a 2 arm the magnetron coil will be a drop in.
  #58
Old 11-03-2008, 05:33 PM
the reason i don't like my armature is because at the end of the lead there is no boot, just a metal circle and if i get close to it i get shocked. however, i won't replace it if there is an effective way of protecting me and other people from getting shocked
Wigster
  #59
Old 11-03-2008, 05:41 PM
crazycart's Avatar
RedNek Engineering
Im sure you can still buy boots...look on ebay. Or cover it in a bunch of electrical tape.
  #60
Old 11-03-2008, 06:07 PM
Russ2251's Avatar
Most older small coils did not use a boot. A shorting clip was used to kill/ground ignition by pressing it against top of exposed plug wire. Was very common at one time.
Jolt you get won't kill ya'.
Had a girl friend whose father would check car ignition by grabbing open plug wires while engine was running.
To see him just 'shake it off ', like nothing happened, truly amazed me. He told me he was used to it.
Closed Thread
