Closed Thread
  #61
Old 09-05-2013, 10:11 AM
OzFab's Avatar
OzFab OzFab is offline
I can answer the second question...
Quote:
Originally Posted by chuggins08 View Post
( 20 or so hours)
  #62
Old 09-05-2013, 12:36 PM
chuggins08 chuggins08 is offline
i have the bolt that says what the crankshaft is threaded for. I am putting enough loctite to get all the threads. By wiggly, I mean i can move the bolt up, down, and to the sides. but the farther I go into the shaft, the more stable the bolt gets. It is weird. The bolt does not come loose while I have it on the stands, only when I actually get in and drive it. I got a longer bolt this morning; so i am going to take it for a test drive in a little while.
  #63
Old 09-05-2013, 01:26 PM
Just took it for a test drive and the bolt did not loosen itself, but the chain came off. I am thinking the chain is too loose and its jumping off the sprocket.
  #64
Old 09-06-2013, 08:08 AM
Well I loosened the engine mount bolts and moved it forward to tighten up the chain. Took it for another test drive a few minutes ago and the bolt loosened up on me again. This time it lasted about 30 yards...
  #65
Old 09-06-2013, 09:33 AM
itsid's Avatar
itsid itsid is online now
you're sure the set screws you used as key are still intact?
maybe they're sheared off.
  #66
Old 09-06-2013, 09:45 AM
OzFab's Avatar
Something is drastically wrong here... Either you have the wrong size bolt or the clutch is not on the shaft far enough. Remove only the bolt from the end of the shaft, take a pic & post it...
If possible, also take a vid of the "wiggly" bolt movement...
  #67
Old 09-07-2013, 02:15 AM
fowler's Avatar
fowler fowler is offline
here is a quick video of how a bolt should sit in the threads
i dont know why its gone into portrait but anyhow
That's not an oil leak
It's horsepower sweat
  #68
Old 09-08-2013, 08:35 PM
slideways slideways is offline
Use a battery powered impact gun. Not a pipe wrench. You also need to have the "guts" completely under the drum so space the crank with spacers.
Are you sure when you tighten the bolt that the drum still spins free? If the drum spins along with the crank you have an issue with the mandrel and its locking together and just spinning the bolt right out as you move forward. We need more pics of the clutch and the way you have it put together to make sure you have all the parts assembled right.
  #69
Old 09-09-2013, 08:17 AM
mckutzy mckutzy is online now
With all this effort, How much would it be for a new crank shaft.
For the most part it sounds/looks like the threads are bunged up some how and that what is the problem.
I cant say re-tap the threads cause its hardened, so a new shaft might be in order.
  #70
Old 09-09-2013, 08:22 AM
landuse's Avatar
landuse landuse is offline
You could retap. Many people have drilled and tapped shafts. It is a common practice
  #71
Old 09-09-2013, 08:23 AM
really... ok. Not that hardened??
OP why not re-tap the threads then? or get a shop to do it for you.
  #72
Old 09-09-2013, 08:28 AM
landuse's Avatar
You can just think of how many people have cut keyways and turned their shafts down on lathes. Not too difficult
  #73
Old 09-09-2013, 08:32 AM
I get that, but grinders and carbide tooling are harder than case or through hardening of most shaft steel.
I have worked on electric motor shafts but I would think that an internal combustion engine crank shaft would have been more tougher, well none the less good to know.
  #74
Old 09-09-2013, 09:41 AM
OzFab's Avatar
Yes, the crankshaft is hardened steel but, any decent tap is carbide, much harder than hardened steel
When I turned down my crankshaft, HSS wouldn't touch it but a carbide bit ate it... (it wasn't much good after though )
Having said all that, Chuggins, try a M10 bolt, just to rule it out...
  #75
Old 09-10-2013, 04:43 PM
philip metzner philip metzner is offline
I thing there is something wrong here that we are assuming is right because it is considered common knowledge. Things like, the clutch doesnt fit the shaft right, or sprockets are out of alignment, or engine is crooked, or clutch is jammed on a tapered crank, ect. What happens if the bolt comes loose?? If everything is right and the set screws are tight, the answer should be nothing. If the clutch is trying to walk off the shaft something is wrong. Why does the clutch drum have marks on it from the chain pins? Why did the chain come off the one time the bolt stayed in?
  #76
Old 10-10-2013, 09:51 PM
edgeblade edgeblade is offline
Any new updates on this?
Closed Thread
