Closed Thread
  #41
Old 08-14-2013, 12:13 AM
mymumisaman mymumisaman is offline
If all else fails couldn't you put a bearing between the bolt and what your connecting it to? This should stop any excess movement from undoing the bolt, but it sounds to me that something is catching it or its not lubricated properly,
  #42
Old 08-14-2013, 02:20 AM
Russ2251's Avatar
Russ2251 Russ2251 is online now
Powered by LAWN-BOY
Quote:
...couldn't you put a bearing between the bolt and what your connecting it to?
Adding a bearing would exacerbate the situation and is not required.
There is no (or should not be) any movement there.
OP needs to find out why it's doing something it's not supposed to do.
I suspect it's key or clutch bearing related.
https://www.youtube.com/watch?v=c4jch0puM1A
  #43
Old 08-14-2013, 07:02 AM
itsid's Avatar
itsid itsid is offline
You sure you have the right bolt?
check engines manual what size and thread pitch you need,
and the correct length (an inch or so)?
  #44
Old 08-14-2013, 07:03 AM
Russ2251's Avatar
Powered by LAWN-BOY
Should be 5/16"x24.
  #45
Old 08-14-2013, 07:31 AM
itsid's Avatar
5/16?? isn't that small? I though 5/8x24 if it's a honda and actually made for the US Market...
Anyways, if it's a clone (or european honda) it can also have a metric bolt like 10x1.5
  #46
Old 08-14-2013, 07:38 AM
Russ2251's Avatar
Powered by LAWN-BOY
My bad... 3/8"x24.
  #47
Old 08-14-2013, 05:34 PM
chuggins08 chuggins08 is offline
the bolt is 3/8x24. I have right bolt. I got some key stock, so I am going to cut what I need and put that in there. Does that bolt that's there instead of the other set screw going to make a difference. Its the same size and everything it just has a head...
  #48
Old 08-14-2013, 05:49 PM
Russ2251's Avatar
Powered by LAWN-BOY
I would get the correct screw. Local hardware store should have it or can tell you where to get it.
  #49
Old 08-14-2013, 06:06 PM
yeah I am going to check ACE Hardware tomorrow. Lowes and Home Depot had set screws all around the size I needed, but did not have the size I needed. Doesn't that just make you mad....
  #50
Old 09-04-2013, 02:58 PM
I got everything put back together and the bolt is still backing out. I got the correct set screws and key stock. I put everything back on yesterday and let the loctite sit till i got home from work today ( 20 or so hours ). I literally went about 20 yards and the bolt loosened and the chain fell off. Any other ideas on what could be causing this???
  #51
Old 09-04-2013, 04:07 PM
I just dont get how the bolt could still be loosening itself. I have the right hardware, i have a lock washer, and I have loctite on the bolt. Doesn't make any sense!!!
  #52
Old 09-04-2013, 04:28 PM
The only thing that springs to mind is either, the direction the engine is turning, is the same to the thread in the hole, or something is catching the bolt causing it to undo, is the clutch mooving freely from the shaft of the engine? Some close up pics would help too
  #53
Old 09-04-2013, 04:39 PM
the engine turns counterclockwise while the bolt turns clockwise to tighten. the clutch drum moves freely, but the clutch itself does not.
  #54
Old 09-04-2013, 04:41 PM
Doc Sprocket's Avatar
Quote:
Originally Posted by Doc Sprocket View Post
I am really wondering what's there, though. The bolt (and any hardware associated with it) should NOT apply or encounter ANY friction to the clutch drum. Since the drum spins toward "loosen", I suspect something is wrong... Something isn't right.
Any thoughts on this^ ?
  #55
Old 09-04-2013, 04:56 PM
itsid's Avatar
Well any bolt can rattle itself loose on a kart I guess if the thread is worn or it's not tightened properly etc.
So I don't think it's because it's the PTO shaft bolt
  #56
Old 09-04-2013, 06:27 PM
tomorrow, I am going to run by home depot or lowes and get a longer bolt to see if that helps any. It seems the bolt is a little wiggly where its at right now, which I think could be causing it to rattle loose.
  #57
Old 09-04-2013, 07:47 PM
philip metzner philip metzner is offline
I dont know anything about clones but I assumed they would be metric threaded.
  #58
Old 09-04-2013, 07:52 PM
fowler's Avatar
fowler fowler is offline
A little wiggly
What do u mean by that?
Do u mean it is loose on the threads as in u can jiggle it back and forth up and down
Sounds like the wrong bolt
This situation is just odd
Can u take a video
Put the back wheels up in stands and the front wheels up against a wall
Crank up the engine and film the bolt coming loose
That's not an oil leak
It's horsepower sweat
  #59
Old 09-05-2013, 06:38 AM
Quote:
Nah- If they are destined for the North American market, they are threaded for imperial hardware.
  #60
Old 09-05-2013, 09:31 AM
mckutzy mckutzy is offline
Just a quick question OP- How much locktite are you using on the bolt, Just a line across the threads or basically dipping the whole threaded part in the glue?
How much time for set up before riding or starting?
Closed Thread
