Closed Thread
  #21
Old 08-12-2013, 10:26 AM
Doc Sprocket's Avatar
It should go all the way on. What prevents it from doing so?
  #22
Old 08-12-2013, 10:28 AM
chuggins08 chuggins08 is offline
the drum part does not fit over the shaft, it gets bolted onto the end of the shaft. The inner part of the clutch, which contains shoes and springs, can go all the way on, but how would the clutch work then?
  #23
Old 08-12-2013, 10:38 AM
Russ2251's Avatar
Russ2251 Russ2251 is offline
Suspension? Not a GoKart!
I get it.
Clutch housing bore end is smaller diameter than shaft so that, in effect, it bottoms out.
https://www.youtube.com/watch?v=pzrp0eki0Fo
  #24
Old 08-12-2013, 10:39 AM
correct
  #25
Okay- If I am comprehending correctly, it is done on that model because of the low tooth count, which makes for a smaller sprocket diameter. I would be awfully inclined to cut a sleeve/spacer out of some tubing that will take up MOST of the rest of the free space on the shaft (leaving maybe 1/32" free play).
EDIT- Russ... Whaddya think? Sleeve? No? I have not used such a clutch.
  #26
Old 08-12-2013, 10:47 AM
could that be why the bolt is loosening? Cause there is so much of a gap between engine and clutch?
  #27
Old 08-12-2013, 10:51 AM
Russ2251's Avatar
I have an old 1" bore Comet clutch which is very similar to his Noram Enforcer and I don't use a sleeve...except for the fact that my PTO is 7/8". I had to make up the difference and does not extend all the way down shaft. This is best pic I could find of said setup:
  #28
Old 08-12-2013, 10:56 AM
So what should I do?
  #29
Old 08-12-2013, 11:19 AM
OzFab's Avatar
OzFab OzFab is offline
Umm, no! You don't use the set screw as the key, you tighten it down on the key. Furthermore, the bolt you're using in place of the second set screw will be causing all manner of problems. Take everything apart & start again using the correct hardware
  #30
Old 08-12-2013, 11:30 AM
I think that as long as the drum is shouldered securely to the end of the shaft, you should be okay without any spacers or anything. I am really wondering what's there, though. The bolt (and any hardware associated with it) should NOT apply or encounter ANY friction to the clutch drum. Since the drum spins toward "loosen", I suspect something is wrong. You tighten it down with a pipe wrench (ecch!) and the bolt blows back out in a heartbeat. Something isn't right.
  #31
Old 08-12-2013, 11:37 AM
the clutch did not come with a key...
  #32
Old 08-12-2013, 11:43 AM
mckutzy mckutzy is online now
Is there a keyway milled in the bore to accept a key?
  #33
Old 08-12-2013, 11:44 AM
Does it have a slot in it for a key? It should. Hardware stores carry key stock. Buy a length, cut to size with hacksaw or grinder.
  #34
Old 08-12-2013, 07:09 PM
so those things described above are prolly the things causing the bolt to back up?
  #35
Old 08-12-2013, 08:01 PM
yes. I do think so. Especially what I said in post #30 with relation to friction on the bolt.
  #36
Old 08-13-2013, 12:12 PM
Russ2251's Avatar
This pic should clear things up.
As usual, there is a snap ring which holds c-clutch together.
When bolted to engine, washer butts up against clutch shaft.
Clutch shaft, from what I can tell, has a key way. Probably .25"?
As far as grub screws go...not all of them are located over key. Mine are not.
A point here that has not be mentioned. Keys come in oversize as well as under size. I choose the oversize so that I can customize them to fit.
The only way that I can reason that bolt loosens is because key is missing thus allowing clutch shaft to move on PTO.
If this is the case, then clutch shaft and/or PTO may be damaged.
By the way...the Noram Enforcer is a $200+ item!
  #37
Old 08-13-2013, 12:14 PM
I am going to get correct set screw, some key stock, and re-do everything including making sure the cranshaft is dry when I put loctite on the bolt to hold the drum on. I will try to do this tomorrow after class, and i will test drive it again tuesday to see how it goes. Hopefully this will fix it.
  #38
Old 08-13-2013, 12:15 PM
What is the PTO?
  #39
Old 08-13-2013, 12:20 PM
Russ2251's Avatar
Quote:
Originally Posted by chuggins08 View Post
What is the PTO?
Power Take Off
End of shaft that clutch is fastened to.
  #40
Old 08-13-2013, 12:24 PM
Ok, well ill get back with yall in a few days and tell yall how it went. thanks for all the help!
Closed Thread
