Closed Thread
  #21
Old 09-15-2008, 01:38 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Quote:
Originally Posted by I like karts View Post
Im probably going to be using a 24mm mikuni, so the gas will have an external pump
The mikuni runs a pressurized bowl and should work well.
  #22
Old 09-15-2008, 02:17 PM
jr dragster T's Avatar
jr dragster T jr dragster T is offline
Dude...your going to JB weld or epoxy a bearing to some plastic pipe. Just the belt tension will crack the JB weld. And most flywheels have a tappered shaft so good luck!
  #23
Old 09-15-2008, 06:34 PM
ed1380's Avatar
ed1380 ed1380 is offline
Banned
another reason to use blower impeller. its not tapered and since its more efficient you wont need it spinning as fast
  #24
Old 09-15-2008, 07:00 PM
Quote:
I couldnt agree more man. Its perfect because you already have a inlet, Outlet and bearings and such. You could make some pretty serious boost!
  #25
Old 09-15-2008, 07:50 PM
Quote:
What do you mean its pressureized? Meaning I cant run a gravity setup with a mikuni?
  #26
Old 09-15-2008, 08:05 PM
Kartless....
It has a little fuel pump inside it that keeps pressure inside the carb, it has a needle/seat that works on pressure not a float allowing it to work in any direction. The being pressurized bit will make running a blower through it alot easier.
  #27
Old 09-15-2008, 08:23 PM
crazycart's Avatar
crazycart crazycart is offline
RedNek Engineering
Which Mikuni are you talking about??? If its the round/flatslide ones, they have floats.
For some there is therapy...For me there is motorcycles...
  #28
Old 09-15-2008, 08:27 PM
crazycart's Avatar
RedNek Engineering
Also, it would be much easier to just buy a freakin' used turbo off a smaller car engine and modify that to work not some ghetto rigged flywheel that doesn't produce nearly as much boost as a actual turbo that was designed for it....just my 2...
  #29
Old 09-16-2008, 05:49 AM
Quote:
Thats what i was thinking. But there was a guy that posted a Picture of a mikuni diaphram carb here a coulple weeks ago.
  #30
Old 09-16-2008, 01:37 PM
ed1380's Avatar
Banned
yes except that even a small turbo a briggs will have a hard time spooling up
  #31
Old 09-16-2008, 02:45 PM
crazycart's Avatar
RedNek Engineering
Well you could either do it the exhaust way or run a belt to the turbo impeller. I doubt it would make much difference since your using a little flathead anyway
  #32
Old 09-16-2008, 07:22 PM
I like karts's Avatar
I like karts I like karts is offline
Rotary Power!
the blower idea is good, I might try it if i can find a donor blower
and a real turbo first off means lots of fabrications of brackets and such, and its too complicated cause you have to have an oul tank. plus its heavy
  #33
Old 09-17-2008, 02:27 AM
fluxcored fluxcored is offline
Sir, you do know that this is the stuff legends and billionares are made of? An odd ball with a crazy idea which everybody sez and dismisses as not doable or not worthwhile.
I have got nuffink other than moral support that I can offer you in your quest for fame and excellence.
GO FOR IT!
The Following User Says Thank You to fluxcored For This Useful Post:
I like karts (09-17-2008)
  #34
Old 09-17-2008, 02:11 PM
Kartless....
A hairdryer modded to run off the crank would work well.
  #35
Old 09-17-2008, 02:22 PM
dlcalhoon dlcalhoon is offline
Junior Member
12,000 rpm epoxy and a straight rod, you are on the right track thinking of supercharging, but beware with those kind of rpm's and the extra heat generated by the air being compressed and the weight of the rotating mass of the flywheel. You will need bearings and some kind of lubrication. Also keep in mind that what ever you puff in has to be able to get out just as fast if not faster to work. If it doesn't explode and fly apart first you will also have to lower the compression ration and retard the timing to avoid detonation. Good luck
  #36
Old 09-17-2008, 10:16 PM
modelengineer modelengineer is offline
Lord of the noise
There's a video on youtube of someone who has supercharged a briggs. I think its a flathead. He also turbocharged it. Just try searching on youtube.
Andrew
GS500F powered...
  #37
Old 09-18-2008, 03:41 PM
Yeah I saw that video. They both run like crap!
  #38
Old 09-18-2008, 07:21 PM
Jblankster's Avatar
Jblankster Jblankster is offline
WHY DONT YOU JUST!
put nitrous on your kart? ive seen it done, in fact i got pics.
  #39
Old 09-18-2008, 07:30 PM
I would seriosly drop the epoxy, Pipe and flywheel method and look for safer performance enhancments! Like seriosly whats a cam and some porting gona cost?
  #40
Old 09-18-2008, 09:17 PM
ed1380's Avatar
Banned
http://www.youtube.com/user/djrevolution99
this guys vids. hes turbod and fuel injected small engines
Closed Thread
