Closed Thread
  #61
Old 01-15-2013, 04:16 PM
zip kart zip kart is offline
yes there is a o-ring already in the carb as u can see in the pictures
would it not go like this
carb
o-ring
spacer
o-ring
paper gasket
intake manifold
maybe not just in the picture of the manifold i thought the paper gasket goes there or would the spacer and o-ring be enough would it be stupid the way i said?
  #62
Old 01-15-2013, 04:18 PM
Doc Sprocket's Avatar
There would be no reason for an O-ring to seat against a fibre gasket.
  #63
Old 01-15-2013, 04:23 PM
fowler's Avatar
fowler fowler is offline
Sort of silly that way
A gasket would stop an o ring sealing
An o ring would stop a gasket sealing
The gasket will go on the intake manifold toward the block
That's not an oil leak
It's horsepower sweat
  #64
Old 01-15-2013, 04:27 PM
ye ino so theres no need for the paper gasket then
  #65
Old 01-15-2013, 04:30 PM
if that doesnt sort my problem i dont no what will ?
  #66
Old 01-15-2013, 04:59 PM
OzFab's Avatar
OzFab OzFab is offline
Quick off topic point: At the bottom right corner of each of your posts is an "Edit" button; please use it rather than making multipe posts a few minutes apart...
  #67
Old 01-15-2013, 05:16 PM
fowler's Avatar
Just keep the paper gasket, don't throw it away
It's a new part u may need it later on
  #68
Old 01-19-2013, 05:49 AM
is there apposed to be a spring on the float bowl thing ,maybe mine doesnt float works properly i checked it
  #69
Old 01-19-2013, 05:51 AM
also the fact that its running lean it doesnt cut out or anything so is it ok
  #70
Old 01-19-2013, 02:08 PM
The fuel inlet needle should be retained to the float with some sort of clip.
  #71
Old 01-19-2013, 04:57 PM
yes it does you can see it in the picture
Closed Thread
