Closed Thread
  #21
Old 01-08-2013, 06:43 AM
zip kart zip kart is offline
heres some pics of the carb bowl gasket as u can c its not a o-ring gasket and its still in place if u look closely u can see the split but its not bad
as for the manifold gasket theres a few pieces gone out of it but i used gasket maker to fill in the gap ,but i took it off to show ye the broken part
and another thing theres some sort of breather that comes off just at the start of the exhaust if u have any idea what its for its not connected up to anything either i got the quad like this maybe it has sometime to do with my problem i dont know
pictures arent great but thats the best i could get
  #22
Old 01-08-2013, 03:18 PM
fowler's Avatar
fowler fowler is offline
The reason u can't find an intake gasket is because its not a gasket
The plastic bit is simply a spacer with o rings in it
U should be able up find one of those o rings
How was the plastic Brocken?
The gasket maker won't work in that place
Get some body filler or something to fill in those holes then get some new o rings
Motor bikes rarely (I've never seen ) use a carb gasket they use either a boot and clamp or an O ring
U can super glue an o ring back together
That's not an oil leak
It's horsepower sweat
The Following User Says Thank You to fowler For This Useful Post:
zip kart (01-09-2013)
  #23
Old 01-09-2013, 09:32 AM
but is that the problem ,if i replace the spacer for the intake
will that solve my problem ?
so is the carb bowl gasket ok can i super glue the part thats split back together
  #24
Old 01-09-2013, 01:03 PM
its hardy the intake gasket then is it ?
  #25
Old 01-09-2013, 02:23 PM
fowler's Avatar
No u gotta replace / fix the spacer
more importantly replace the O rings in it
Is there a similar o ring in either the block or carb?
If there isn't then there may be a circular slot where u can fit one
  #26
Old 01-09-2013, 03:10 PM
ok il order a new spacer and o-ring am yes there is a o-ring where the carb connects to the intake and then the other spacer goes in between if u know what i mean
so you think its the spacer and o-ring?
  #27
Old 01-09-2013, 03:16 PM
fowler's Avatar
Right if there's an o ring in the carb then the o ring in the spacer faces to the block
An obvious thing to say but important
Re order that o ring as well
  #28
Old 01-09-2013, 03:22 PM
the o-ring thats in the carb doesnt look bad or anything
i super glued the split in d carb bowl gasket aswell because i cant get a new 1 anywhere will that work
  #29
Old 01-09-2013, 04:48 PM
Doc Sprocket's Avatar
That exhaust thing- I have no clue what it is. A friend of mine (rather foolishly, if you ask me) just bought a brand new chinese quad for his young niece. I noticed it had that part, and didn't make a lot of sense to me. I can't remember right now if it had wires or a vacuum mine to it, but the only thing I can figure is an emissions thing. Perhaps under the right circumstances, it admits fresh air into the exhaust to help burn of remaining fuel or something... Beats me.
The Following User Says Thank You to Doc Sprocket For This Useful Post:
zip kart (01-10-2013)
  #30
Old 01-09-2013, 05:56 PM
OzFab's Avatar
OzFab OzFab is offline
Quote:
Yes it is. It also appears to be too small (in diameter)
Quote:
you can but, it tends to make it hard & brittle; not the best properties for a rubber gasket
Replacing the O ring should solve your problem but, play it safe, repair/replace it
As stated above, it's not the best solution. Chances are, if the ring has split, the whole thing has hardened & won't seal even if you did repair it
IMO, either replace the gasket or, if you can't get one, run a bead of silastic (not just plain old silicone) in the groove in place of the gasket. If that doesn't seal it, nothing will. Be sure to use fuel resistant silastic
The Following User Says Thank You to OzFab For This Useful Post:
  #31
Old 01-10-2013, 10:17 AM
so il order a new gasket spacer and o-ring is that everything i need then ?
  #32
Old 01-10-2013, 04:40 PM
fowler's Avatar
Nope that's about it
Unless u are going to silastic the carb bowl
I've never had a problem with a glued o ring and most of mine take 3200psi
But it is an emergency thing so if u can find a new or then its prefered
  #33
Old 01-10-2013, 04:44 PM
so i dont have to worry about the vacuum pipe or what ever it is that comes off the exhaust . its not important or anything is it?
  #34
Old 01-10-2013, 04:47 PM
fowler's Avatar
I didn't see that
No idea what it is
Why can't u re fit it?
Otherwise try tuning it without it
If it works then u are set
  #35
Old 01-10-2013, 04:52 PM
i dont no where it goes or whats it for
pictures arent great because its connected where the exhaust starts at the engine ,thats why its hard to see
  #36
Old 01-12-2013, 02:12 PM
can anyone tell me this
i cleaned out the carb and i took out the idle screw and fuel screw so i could clean them and now i dont no how far i should have them screwed in
if i screw them in the whole way how many turns will i screw them back out?
any help would be great
  #37
Old 01-12-2013, 03:26 PM
I hate to kick a guy when he's down, but-
You goofed. Before taking any adjustment screw out of a carb, you screw it IN while counting the turns until it gently seats. That way, you know exactly how many turns out from seated it needs to be when you re-assemble it.
Without a service manual, dunno. Trial and error.
  #38
Old 01-12-2013, 03:42 PM
so no1 has no idea then ?
  #39
Old 01-12-2013, 03:43 PM
i didnt take out the fuel screw only the idle screw
  #40
Old 01-12-2013, 04:40 PM
OzFab's Avatar
Well, that's not what you said previously
Screw it in until it touches the stop point & the butterfly linkage moves slightly
Closed Thread
