Closed Thread
Old 01-05-2013, 06:50 AM
zip kart zip kart is offline
Default iv a question about a carb bowl gasket
hi i have a 110cc quad
and the carb bowl gasket is split but is still in place and i cant get a gasket anywhere for it would i lose power the way it is ?
Old 01-05-2013, 07:06 AM
fowler's Avatar
fowler fowler is offline
Is the engine a lifan
Find a lifan gasket and it may be correct
U won't loss power but u may leak fuel onto the gear box causing a clear fire hazard
That's not an oil leak
It's horsepower sweat
Old 01-05-2013, 11:13 AM
loncin cant find any
Old 01-05-2013, 11:18 AM
DS13's Avatar
DS13 DS13 is offline
Annoying the Neighbors!!!
i found a whole carb for $27 if your intrested... idk if will fit but here is the link
http://www.kazumausaonline.com/carbu...le-p-6592.html
Two wrongs may not make a right but three lefts will
http://www.diygokarts.com/vb/showthread.php?t=16543
The Following User Says Thank You to DS13 For This Useful Post:
zip kart (01-05-2013)
Old 01-05-2013, 11:34 AM
Doc Sprocket's Avatar
Measure it up. Perhaps a hardware store will have a big enough O-ring.
And if it's peeing fuel fast enough, you will lean out and lose power. But, IMO if it reaches that point, you got bigger problems than a loss of power.
The Following User Says Thank You to Doc Sprocket For This Useful Post:
Old 01-05-2013, 04:44 PM
need help here lads ,my fuel richness is messed up i checked to see what colour the spark plug was and it was whitish colour does that mean its running too lean?how to do i know when theres enough fuel going to the engine ,idle is ok but im just worried about the spark plug being whitish
  #7
Old 01-05-2013, 06:47 PM
OzFab's Avatar
OzFab OzFab is offline
White plug = lean, dark brown = rich. Start by adjusting the mixture
  #8
Old 01-05-2013, 10:06 PM
Before you take a screwdriver to that carb, ask yourself- "Why is it too lean?"
Seems to me that we were recently discussing one or more potentially bad gaskets...
  #9
Old 01-07-2013, 10:32 AM
yes how come theres no gas leaking out of the carb then ?
  #10
Old 01-07-2013, 02:37 PM
Quote:
I am having a difficult time making sense of this question. If the bowl gasket is bad, it will usually leak to some degree. If the manifold gasket is bad, it will not leak fuel out, it will leak air in (causing it to lean out). Engine vacuum prevents fuel from leaking out.
zip kart (01-07-2013)
  #11
Old 01-07-2013, 04:56 PM
the carb gasket is split but i have it connected back up and its grand now so theres no fuel leaking and there wasnt really any fuel leaking out of there in the 1st place
by the manifold gasket do u mean the tick plastic 1 or is there another gasket in between that 1 ,and theres a piece gone out of the tick gasket but i put gasket maker on that ,but would that be causing my problem?
  #12
Old 01-07-2013, 05:17 PM
see if its the carb bowl gaskets iv a problem because i cant find anywhere where they sell carb bowl gaskets for a 110cc loncin quad ,its a mikuni carb aswell ,but is there any way i can make my own rubber carb gasket or repair the old 1 ,but if i need to replace the manifold gasket i can get them off ebay ,so any ideas?
  #13
Old 01-07-2013, 06:33 PM
You might be lucky enough to find a large O-ring that will fit, at a hardware store. As for the manifold gasket (more than 1 possible, depending on application) you can get them nearly anywhere like EvilBay, or even your local OPE shop. If you're careful about it, you can make them. I do.
EDIT- Thick plastic? that's not a gasket. And if ANYthing leaks between the carb and the inlet port, then you're going to have problems.
  #14
Old 01-07-2013, 06:45 PM
i cant really make a the carb bowl gasket out of a o-ring because its not in a shape of a o-ring ,the best thing for me today is to wait till i upload some pictures of the the gaskets and then you will have a good idea
  #15
Old 01-07-2013, 06:47 PM
Probably a good idea.
  #16
Old 01-07-2013, 08:06 PM
mckutzy mckutzy is offline
While on the subject of Gaskets.
toystory_4wd- What do you make your intake manifold gaskets out of? A fiber material or like a rubber?
  #17
Old 01-07-2013, 08:10 PM
I've done both with success. I have a selection of various materials, including *GASP!* asbestos.
  #18
Old 01-07-2013, 08:25 PM
So like what, cereal box,milk carton, news paper?
Sorry got me thinking about the potential mix leaning out on this guy carb, and my situation on my bike.
  #19
Old 01-07-2013, 08:39 PM
Any gasket is better than no (or fried) gasket. As long as the material is up to the task. I wouldn't use straight fibre (paper) on the exhaust, for example. On things like side covers, you've got to watch the thickness to keep crank endplay within spec.
Folks have been known to use cereal boxes and other similar card stock with success. Often, when I use a fibre-type material, I will give it a light coat of engine oil upon installation. I don't know if it actually does anything to improve the seal, but my brain tells me it does... So I do- and have not had any problems with home-made gaskets to date. FWIW- I use a set of leather punches to make the bolt holes, and a #11 X-Acto knife or crash scissors to cut the material.
  #20
Old 01-07-2013, 09:21 PM
Cool, When I used to work on electric pumps and other motored devices, we used a vegetable fiber paper with an oil impregnated within it. I was thinking of this as I last typed but wanted to see what others have used. My exhaust gasket for my straight pipe, is a copper sheet cut to fit the factory shape. Works good as far as I can tell.
Closed Thread
