Closed Thread
  #21
Old 11-08-2012, 12:10 AM
OzFab's Avatar
OzFab OzFab is offline
Waddaya mean "almost"
  #22
Old 11-09-2012, 02:01 AM
OzFab's Avatar
Who can tell me the difference between a GX140 head & a GX160 head? I'm not too concerned about the size of the combustion chamber, valve size & bolt alignment are the main issues
  #23
Old 11-09-2012, 02:47 AM
landuse's Avatar
landuse landuse is offline
Quote:
I know R_chez has mentioned what the difference is, but I cannot for the life of me remember what it was. PM him
  #24
Old 11-09-2012, 07:14 PM
OzFab's Avatar
I would if he'd empty his inbox!
Paging r_chez...
  #25
Old 11-12-2012, 04:02 AM
landuse's Avatar
Paging r_chez...
I am so stupid. I thought "let me PM r_chez for Fabroman", and then halfway through my PM I went.....DOH
  #26
Old 11-19-2012, 08:07 PM
OzFab's Avatar
Quote:
Duh!
Anyhoo, here's the reason I asked in the first place (see pics):
After examining both heads, I can tell you the 160 has bigger valves & ports than the 140. Everything else (guides, stud pattern, overall size) is identical. Thanks chez
I'm currently examining which road would be easier (& cheaper) to take; weld up the 160 head or mod the 140 head to suit.
  #27
Old 11-19-2012, 11:59 PM
landuse's Avatar
If you can mod the 140, it might be eisier. It looks like you are not going to be able to fix that exhaust bolt hole. It looks like it has been fixed before
  #28
Old 11-20-2012, 12:22 AM
OzFab's Avatar
That's what I'm thinking. With any luck, it won't be too difficult to mod.
  #29
Old 11-20-2012, 01:01 AM
landuse's Avatar
So how are you planning to make the ports larger. A dremel type tool?
  #30
Old 11-20-2012, 01:19 AM
OzFab's Avatar
Yep, if I can. I have to find out how much meat is behind them first; hopefully, lots
  #31
Old 11-20-2012, 10:07 AM
OzFab's Avatar
Ok, can someone please explain this to me:
I just had both heads side by side to confirm the aforementioned differences between the two. Then I looked at both carbs & their spacers & found they're identical?
So, on the smaller engine you have a carb which then goes to a spacer/adapter which goes from the shape of the carb throat to the shape & size of the port. On the larger engine, the same applies until you get to the port which is 1/8" larger than the spacer. The port then tapers down to be approximately the same size on both heads.
Now, if I understand the concept correctly (which I think I do), the increased size of the port compared to the spacer would cause a loss of velocity as the fuel enters the port &, worst case, create a vortex which would slow the fuel dramatically, correct? Yes, it would pick up again as it travels through the port but, wouldn't it be more efficient if there was no loss at all?
Basically, what I'm asking is, wouldn't I be better off with the smaller port anyway?
Pic legend: Pics 1 & 3; 140 are on the left. Pics 2, 4, 5 & 6 140 are on the right.
  #32
Old 11-20-2012, 11:25 AM
exenos's Avatar
exenos exenos is offline
Project Nut
I'd pm the guy who started the porting thread, its in the engine sticky's. He should be able to help you since he does porting professorially.
  #33
Old 11-20-2012, 03:47 PM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
Roger that!
I could empty my inbox but thats an effort!
Pretty sure the 140 head has smaller ports. The 120 definently does.
Think its still a 14cc head tho.
Edit: haha oops, sorry for trying to have a life guys
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
  #34
Old 11-20-2012, 04:14 PM
OzFab's Avatar
Quote:
Did that yesterday awaiting reply
Quote:
Originally Posted by r_chez_08 View Post
Roger that!
Finally, I tried to PM you a week ago!
That's what I'm saying, the combustion chambers are the same, the head overall is the same, the only difference is the ports & valves. Everywhere I search I get the same result; 140, 160 & 200 all use the same carb. Oh, here's another weird thing, the 140 carb has a bigger jet
  #35
Old 11-20-2012, 04:36 PM
r_chez_08's Avatar
The 160 carb is smaller. Pretty sure 140 carb is the same.
Tbh though, honda changed there designs numerous times so it is hard to give exact specs.
If you have a 160 head, use it. If not, open up the 140 head. Also some valve deshrouding may help.
Use the thinnest head gasket you can for reassembly, maintaining a .025 piston to head clearance. You could skim the head with some wet and dry and some glass too if you wanted.
  #36
Old 11-20-2012, 04:46 PM
OzFab's Avatar
Did you see post #26?
My plan was to reseat the valves, skim/true the head & a bit of mild port work.
  #37
Old 11-21-2012, 12:47 AM
r_chez_08's Avatar
Sorry, just skimmed the thread.
Jb weld to fix the exhaust stud? Or maybe drill is a little deeper and re tap as well as jb weld? Providing it wouldnt go through.
  #38
Old 11-21-2012, 02:06 AM
fowler's Avatar
fowler fowler is offline
devcon the **** outta that hole
That's not an oil leak
It's horsepower sweat
  #39
Old 11-21-2012, 08:03 AM
OzFab's Avatar
Quote:
I thought of that but, first I have to remove what's left of the old stud; I'm having a hard enough time trying to remove the good ones.
I even thought of having it welded properly. then I'd have to redrill the hole, tap it & file it.
Still waitiing for a response from ammfab about the ports
  #40
Old 11-21-2012, 10:31 AM
r_chez_08's Avatar
Hey fabroman, just thought-
I have a good quality 160 14cc clone head, i could do a good deal on. Would save you some hassle.
You interested?
Closed Thread
