Closed Thread
  #81
Old 11-08-2012, 06:44 AM
Scarface's Avatar
Scarface Scarface is offline
The spider gears. Is that what will be under the diff?
  #82
Old 11-08-2012, 06:51 AM
landuse's Avatar
landuse landuse is offline
The gears inside will looks something like this
  #83
Old 11-08-2012, 07:16 AM
fowler's Avatar
fowler fowler is offline
Maybe take the diff apart, clean it and post pics first
U may be able to lock it without totat destruction of if
It may pay to post some more pics of the actual diff
U only have to lock 1 shaft to the housing and its totally locked
As in u may be able to make a cheap diff lock
I've heard of the Lincoln locker but we call it the cig locker
It's a performance upgrade for the 18 yr olds $500 drift car
That's not an oil leak
It's horsepower sweat
  #84
Old 11-08-2012, 01:38 PM
Scarface's Avatar
Ok well now I need to figure out how to take it apart.
  #85
Old 11-08-2012, 03:58 PM
fowler's Avatar
please go to manage attachments and add the pics as thumbnails
iv got a large laptop and they still dont fit on the screen
to crack it apart it loks like u have got tha bolts out
but first u must try to get both axles out of the diff if iu cant then dont worry
to crack it u must first take a center punch and put a center pop on each join
so the first join u put 1 pop on one peice and 1 on the other peice
this is so when u reassemble it everything goes back in the correct operantion
its a good practice even if it can probs go togaether any way u always try to put it back as the OEM wanted, in paticular with drive lines as it is likely it is ballenced
now either ap it on the ground a few times or gently tap the joint with a hammer (u can belt it if u have a soft plastic, rubber or wood one)
it should come apart
if it just cracks and there is a little gap in the joint then u an get a screw driver in there and slowly work around increaseing the gap
dont worry if it comes apart and **** goes everywhere, they are really quite simple to reassemble but watch for any escapeing ball bearings or needles
  #86
Old 11-09-2012, 01:24 PM
Scarface's Avatar
It come right apart and there was just bolts holding the axel up to the cart. So I got it open and I will work with it more on Monday. Thanks.
Oh and I added those pics through tapa talk next time I won't do that.
Closed Thread
