Closed Thread
  #41
Old 09-08-2012, 03:44 PM
Iron John's Avatar
Iron John Iron John is offline
Quote:
Originally Posted by anderkart View Post
Not quite 12,000, but there's a guy in this thread: http://karting.4cycle.com/showthread...t=12%2C000+rpm that's claiming he built a 4-cycle briggs animal that reliably revs to 11,500rpm.
That's pretty darn close to your goal/topic in this thread...
Interesting thread. Thanks for posting it. Not too much detailed information about what's inside, though (understandable, since those guys are racers.)
  #42
Old 09-08-2012, 03:49 PM
Iron John's Avatar
Quote:
Originally Posted by B man View Post
Well idk about 12000 rpms.....but...............
Very cool. Injection is so the way to go.
So if you started with 'something' and if you opened up the bore as far as you could, and perhaps reduced the stroke, and used a titanium rod and a lightened piston, and balanced the bejeesus out of it and had full-pressure lubrication (maybe a dry sump setup using an external electric oil pump), and the right valvetrain and cam profile............well, why not?
  #43
Old 09-08-2012, 04:29 PM
Jcotz's Avatar
Jcotz Jcotz is offline
...wasn't there
Quote:
Originally Posted by r_chez_08 View Post
Wow! Fair effort there, but seems to be a massive waste of time IMO for a small engine.
IKR. Thats what I thought.
Are you kidding me? Isn't that what this whole thing is about?
"There is more stupidity than hydrogen in the universe, and it has a longer shelf life."-Frank Zappa
  #44
Old 09-08-2012, 05:21 PM
sexyvicta sexyvicta is offline
i think he means why spend the time and money...just buy a bike/proper racing kart, engine.
  #45
Old 09-08-2012, 08:15 PM
OzFab's Avatar
OzFab OzFab is offline
Quote:
Originally Posted by toystory_4wd View Post
Meh- "right" is a subjective term. Lotta grey areas, there...
Any compromise between "right" and "wrong" is a victory for "wrong"
  #46
Old 09-09-2012, 06:04 AM
Doc Sprocket's Avatar
Quote:
HAHAHA! Got me there!
Actually, the zero concept is one of those things I pretty much refuse to "get". In my eyes, zero is not a number, it's the absence of a number. Let's examine the following-
"My crankshaft has zero endplay". Well, it doesn't seem worth whipping out the dial indicator, does it? Now, try this simple conceptual substitution-
"My crankshaft has NO endplay". None- it's an absence. Immeasureable.
So, sure enough, the geeks and nerds of the world can (perhaps successfully) argue that zero is a number, but to me it doesn't work. Zero is a place-keeper between positive and negative at best. So, na-na-na-na-na-na!
(boy, did I shoot this one off topic!)
  #47
Old 09-09-2012, 06:21 AM
Jcotz's Avatar
...wasn't there
Your thinking is much like the thinking of the romans, (who had not yet conceptually wrapped their heads around "0" when they created their roman numerals. The arabics however, who for the most part created much of our number system, used it and introduced it to the western world in the 12th century. The trouble you are having is that we are defining zero in its form as a word, which is a noun, which is in a way "something". Zero as an abstract concept however, is in fact very possible, and fulfills all the necessary requirements to be a number. Sorry about that...just felt joining in on that one.
  #48
Old 09-09-2012, 07:28 AM
Quote:
Originally Posted by Jcotz View Post
Zero as an abstract concept however... fulfills all the necessary requirements to be a number.
In my own defence- Terrorists, politicians, and lawyers all fulfill the necessary requirements to be considered human- and that don't jibe with me, either!
  #49
Old 09-09-2012, 11:13 AM
Iron John's Avatar
I would like to rename this thread:
"Why not 11,999.99999999999999999999 rpm?"
That would be close enough for me.
  #50
Old 09-09-2012, 11:55 AM
OzFab's Avatar
I thought I might...
Are you calling me a geek or a nerd?
In that last comment, you proved my point. You don't go from -1 to 1, you have zero inbetween.
Look at it like this: we use a decimal counting system, deci being latin for ten. Now, how many numerals are there? If you don't include 0 there are only 9. No, 10 is not the tenth number, it is the first number in the second sequence.
Sincerest apologies to you John
  #51
Old 09-09-2012, 12:06 PM
Iron John's Avatar
Not necessary. I am enjoying it. Sometimes a thread is like a box of chocolates.
  #52
Old 09-09-2012, 12:16 PM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
Lol, yeah. Its cool because it has not really been done DIY before, but bang for buck, it seems pointless. They even have the stock air filter!
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
  #53
Old 09-09-2012, 12:36 PM
Which term would you prefer?
-1 to 1? There's that place-keeper! 10? It's a number on it's own! the "0" is a component of that number.
And yes- dead wrong maybe, but a man's gotta stand on his beliefs!
  #54
Old 09-09-2012, 03:55 PM
Iron John's Avatar
You example, although mathematically incorrect, makes sense to you. But your justification is integer-centric.
Would you agree that a bearing clearance of .00000000000000000000000000001" is a number, according to your belief?
If so, you will have a heck of a time differentiating that dimension from zero.
  #55
Old 09-09-2012, 03:58 PM
Integercentric? And of course the above (minute) fraction is legit. But it's not zero, is it?
Gawd, this is fun!
You DO realize that at this point I'm saying most of this to drive you guys nuts, right?
  #56
Old 09-09-2012, 04:01 PM
... I also have a problem with Pie r 2. Pie are not squared. Pies tend to be round. Some cakes are squared... Bwahahahahahaha!
Sorry, folks. Had a rough week, need some cheap laffs!
  #57
Old 09-09-2012, 04:12 PM
Iron John's Avatar
Gawd, this is fun!
Yes, we do. Trying to edguumicate regardless.
You have just provided information that proves you do not believe your own belief. You agree that that number (.00000000000000000000000000001") is not zero, but there is not a way on Earth to measure it - IOW, to differentiate it from zero (and if there is, add a few dozen more decimal places).
Therefore zero is a number. Proven by your own argument that it is not.
Now, how about those titanium connecting rods?
  #58
Old 09-09-2012, 04:13 PM
Mcbreja Mcbreja is offline
Click image for larger version
You knew this was coming.
Powered by Improbability.
  #59
Old 09-09-2012, 04:21 PM
In all seriousness, I still only see the zeroes in your example as a placekeeper. The tangible number in the sequence is the "1", and the zeroes give reference to the decimal place. In my eyes, the zeroes could just as easily be replaced with various emoticons. The real problem lies in how I view the "value" of zero. It's, well- zero. Look, I know all the math-heads in the world consider it a number, and I'm not gonna argue with a mathematician. I just don't see it the same way I see a "countable" digit.
Quote:
Originally Posted by Mcbreja View Post
Attachment 26018
Oh, shut UP!!!
Although- I've gotta give you guys credit for trying to explain it to me! Thanks!
  #60
Old 09-09-2012, 06:24 PM
Iron John's Avatar
Oh, shut UP!!!
Do you see 0 degrees celsius as a null temperature? Or as 32 degrees fahrenheit?
Closed Thread
