Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 12-22-2006, 08:51 PM
philip metzner philip metzner is offline
Default bicycle frame minibike
hi, has anyone built the minibike from a bicycle? i am thinking of building it and wondered if anyone had encountered any problems with it?? thanks--phil
Old 12-25-2006, 10:32 AM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
if the frame is aluminum, welding will be more complicated. but the pre-built frame might save you some time.
Old 01-04-2007, 08:57 PM
2or3wheels 2or3wheels is offline
What do you mean? just mount a motor on a bike frome or what?
Old 01-05-2007, 04:52 PM
its a free plan from this D.I.Y. site. go back to the main page and look around at the kart and minibike plans. the 26 inch bike is modified and a new bottom part is constructed. i think its neet.--phil
Old 01-05-2007, 07:00 PM
what kind of motor and bike did you use? got any pics. i tink if it were easy i might be able to do it. i dont have a welder so im up the creek without a paddle i suppose. just describe how u set it all up.
Old 01-05-2007, 08:50 PM
its going to be tough to do without a welder. you have to make quite a few small parts and weld alot. i am useing a mc92 McCulloch kart engine.(2cycle)--phil
  #7
Old 01-06-2007, 09:23 AM
ok thanks. good idea going with a 2 stroke. it will give you alot more power than using a 2 and 1/2 briggs, or something liek that. could you post pics? where do you have the chain going crank or rear wheel? i once found a site that slod 2 stroke motors that went on mountain bikes that included everything for 199$ i think. but pics would be fantastic.
  #8
Old 01-09-2007, 07:12 AM
kart62 kart62 is offline
Junior Member
I built a sidecar for my sons bike once. I was fun but the problem I had was that the bike frame was a alloy of some type and the weld wouldnt hold for long. You are almost better off making the connections bolt on. As far as your idea goes, you sound like all of us at one time or another! good luck
Closed Thread
