Closed Thread
  #81
Old 08-06-2011, 07:11 PM
sexyvicta sexyvicta is offline
Quote:
Originally Posted by Russ2251 View Post
Incorrect mag gap affects timing.
Please explain. Cheers
  #82
Old 08-06-2011, 07:49 PM
jrmints1415's Avatar
jrmints1415 jrmints1415 is offline
mag= magneto and he means that distance between the flywheel and magneto
Whats better... the ride or the build???
  #83
Old 08-06-2011, 07:55 PM
yes i realise that... Was asking how the gap affects timing. Cheers
  #84
Old 08-06-2011, 07:57 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
if its not adjusted right, it takes longer to produce a spark and the timing of the spark dosent agree with the rest of the engine so it dosent fire right
Great, now rebuild the engine.
Be a leader not a follower, but if your going to be a follower, follow the right leader
  #85
Old 08-06-2011, 08:00 PM
Quote:
exactly
  #86
Old 08-06-2011, 08:05 PM
so bigger gap = retards timing and smaller gap = advance?
interesting
  #87
Old 08-06-2011, 08:10 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
Powered by LAWN-BOY
Quote:
To a small degree, yes.
Those that can...do. Those that can't...buy a predator.
The Following User Says Thank You to Russ2251 For This Useful Post:
sexyvicta (08-06-2011)
  #88
Old 08-06-2011, 08:18 PM
from the horses mouth (briggs website):
Quote:
ĽAn armature air gap that is too wide will prevent spark. Not true. Well, sort of not true. Briggs & Stratton air gaps cannot be made too wide to prevent spark providing the coil is healthy and the engine is spun over fast enough. A wide air gap, say .030" will ever so slightly retard the ignition timing as the magnetic field takes longer to build within the coil windings
so probably not the issue here.
i wonder did you set the cam timing correctly? maybe its a little out (i assume you had it apart when you were playing with the oil slinger etc)
Was it doing this when fitted to the mower? if so then could be valves need work/adjusting as mentioned earlier.
  #89
Old 08-06-2011, 08:21 PM
kendelrk's Avatar
redneck engineer
you cant pull the motor so fast due to it having no counter balance and a light flywheel, "A wide air gap, say .030" will ever so slightly retard the ignition timing as the magnetic field takes longer to build within the coil windings" even ever so slightly is going to be messing around with it more due to its now sideways than vertical
  #90
Old 08-06-2011, 08:52 PM
Russ2251's Avatar
Powered by LAWN-BOY
My point is...make sure that everything is within factory spec.
What carb are you using?
  #91
Old 08-06-2011, 09:53 PM
karl's Avatar
karl karl is offline
That air cleaner is not helping. Very restrictive. Like having the choke on. Take it off and try.
  #92
Old 08-10-2011, 11:55 PM
CaptCanadia's Avatar
CaptCanadia CaptCanadia is offline
How's it coming?
"Sometimes the wrong choices bring us to the right places."-unknown
Closed Thread
