Closed Thread
Old 02-25-2011, 04:59 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
Default scared to start engine,
im scared to start my honda clone, i took off the throttle arm and found it running WOT, and was backfiring out of the carb, i put it back together, and it looks like it did at stock, but im scared to start the engine, i fear it will blow up and explode in my face,how could i be sure the governor is in the right position?
Old 02-25-2011, 05:09 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
pull the governor linkage FORWARD with your fingers.
let go and if it revvs up keep your finger on the kill switch.
Old 02-25-2011, 05:12 PM
Russ2251's Avatar
Russ2251 Russ2251 is online now
Powered by LAWN-BOY
Have no fear. Have a helper stand by at the ignition switch and ready to kill it if engine runs wild.
Even under the worst of conditions engine will not explode.
https://www.youtube.com/watch?v=c4jch0puM1A
Old 02-25-2011, 05:37 PM
just dont stand in front of it where the connecting rod COULD punch a hole....
Old 02-25-2011, 05:40 PM
kendelrk's Avatar
redneck engineer
i dont want it to explode, and blow like a rod or something, that would suck
Old 02-25-2011, 05:43 PM
freakboy's Avatar
freakboy freakboy is offline
the names 'mater
Cant be scared.
  #7
Old 02-25-2011, 05:46 PM
kendelrk's Avatar
redneck engineer
im not afraid to ride a fast bike, im not afraid of crashing or falling, just something blowing up and making loud noises, i have a medical condition that makes loud noises scare the living **** out of me
  #8
Old 02-25-2011, 05:48 PM
freakboy's Avatar
the names 'mater
Just stay calm and dont panick when you pannick thats when something bad will happen.. I use to be the same way but depending on the situation i mentaly prepare myself for it think of all possibilities that may happen. a box stock clone will not explode within 5 seconds of start up unless the rod bolts are like finger tight. Even if its full rev's
  #9
Old 02-25-2011, 05:59 PM
true. keep your finger pushing the linkage forward. once youstart it, slowly let go. if it speeds up more, then push forward more.
  #10
Old 02-25-2011, 06:00 PM
Doc Sprocket's Avatar
look- you're fine. Have a guy with his hand on the switch. If the engine tries to run away, just kill it immediately. Nothing is going to start and then rev to 10k and detonate in less than a second.
  #11
Old 02-25-2011, 06:18 PM
B man's Avatar
B man B man is offline
Tecumseh FTW!
does a back fire hurt the engine? just wondering.
  #12
Old 02-25-2011, 06:39 PM
freakboy's Avatar
the names 'mater
out the carburetor or the exhaust? I dont see one every now and then hurting the motor at all.
  #13
Old 02-25-2011, 06:43 PM
kendelrk's Avatar
redneck engineer
out of the carburetor,
  #14
Old 02-25-2011, 06:47 PM
freakboy's Avatar
the names 'mater
That means that the intake valve was still open while it was either igniting or poped open after ignition. whats your valve lash set at?
  #15
Old 02-25-2011, 06:59 PM
kendelrk's Avatar
redneck engineer
havent messed with valve lash, what happened was, the first throttle arm i took off and the spring had no tensoin on it, so the 2nd arm the has the rod stright into the governor had no tension so when i pulled the cord it stayed wide open, which is what i thought, which i thought was causing an overflow of gas into the carb and blowing it out the side of it, because i have a k&n air filter with the billet adaptor on the carb
  #16
Old 02-25-2011, 07:11 PM
Translator, please?
  #17
Old 02-25-2011, 07:12 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Quote:
Originally Posted by toystory_4wd View Post
Translator, please?
Not a period in sight.
ASE Certified
  #18
Old 02-25-2011, 07:14 PM
kendelrk's Avatar
redneck engineer
theres not any tension on the spring to the throttle arm so it dosent pull the governor closed when i pull the cord so it backfires because theres to much gas in the carb,
  #19
Old 02-25-2011, 07:17 PM
Have you not redone that governor linkage, yet?
EDIT- What "cord"?
And whaddya mean, "pull the governor closed"? Nothing Pulls the governor closed. The governor does the pulling and pushing on the throttle.
  #20
Old 02-25-2011, 07:19 PM
kendelrk's Avatar
redneck engineer
mom wont let me outside, claims its to cold to work on the engine, yet its not to cold to go out and shovel and walk the dog,
Closed Thread
