  #21
Old 05-07-2019, 09:18 AM
Budget GoKart's Avatar
broke mechanic
The big derp moment LOL just like i went to start my mini bike and it didnt even have a flywheel on it or cover LOL
Buying junk. Fixing junk. And selling junk.
  #22
Old 05-07-2019, 09:35 AM
Currently flathead-crazed
Yeeeeeaaah, that'll keep it from starting.
Local Bird Engineering Nut
  #23
Old 05-07-2019, 02:15 PM
Hellion's Avatar
Hellion Hellion is offline
I'm hot for teacher
Originally Posted by puttskart79 View Post
Finally. The exhaust valve and intake valve were backwards....
Yeah, but this doesn't explain the initial incident. This just means that, after "backfired and dead", you reassembled the engine incorrectly and it had zero compression.
Assuming you have it properly assembled now, does she run?
If it does (doubtful), we won't likely ever know what went wrong because it sounds like you disturbed the "crime scene".
  #24
Old 05-07-2019, 03:16 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Huh??? Putting the valves in backwards won’t make the exhaust open on the intake stroke. Incorrect cam timing will do that.
The Following User Says Thank You to bob58o For This Useful Post:
itsid (05-07-2019)
  #25
Old 05-07-2019, 06:46 PM
itsid's Avatar
itsid itsid is online now
^^Indeed!
If the engine ever ran after modding
it's very likely the engine is now shot..
governor washer still in, flow off, locked the cam, inertia pushed it out of mesh
(and the bearing seat on the crancase cover broke)
and then all went south.
since as OP said it ran.. and it wouldn't have if it's been installed more than a tooth off.
surely not if it's exhaling through the carb
So yeah something's is hidden from our sight for good reason
  #26
Old 05-07-2019, 09:49 PM
KartFab's Avatar
KartFab KartFab is offline
I’m more confused after reading this thread than when I started reading it. ��
The Following 4 Users Say Thank You to KartFab For This Useful Post:
Denny (05-15-2019), Hellion (05-07-2019), itsid (05-08-2019), JTSpeedDemon (05-08-2019)
  #27
Old 05-08-2019, 08:48 PM
bob58o's Avatar
I’ve figured it out. The pushrods were installed Chris cross Like an “X”.
  #28
Old 05-08-2019, 09:12 PM
itsid's Avatar
Originally Posted by bob58o View Post
Ive figured it out. The pushrods were installed Chris cross Like an X.
nahh.. you no listen!
he said..
plate up that is, right?
I mean they're still round.. so the only way for backwards would be upside down... *shrugs*
