  #21
Old 04-20-2019, 12:26 PM
65ShelbyClone's Avatar
65ShelbyClone 65ShelbyClone is offline
Originally Posted by Konnorbye1 View Post
Okay great! I was just confused, because itís the stock jet being used, while more air is coming into the engine because of the air filter. And more power feels like itís being made.
Any idea as to why this jet still works good, Iím still curious?
What kind of air filter is it?
Generally speaking, a free-flowing air filter necessitates larger jets because it reduces restriction. That lesser restriction means there is less vacuum pulling fuel through the jets. The air is also denser and requires more fuel to keep the mixture good. The choke works in a similar way, just much more dramatically.
That makes me wonder if perhaps your air filter doesn't flow as well as it should.
  #22
Old 04-20-2019, 12:43 PM
950speed's Avatar
950speed 950speed is offline
Standard stage one kit that GoPowersports sells
Edit: I do have a foam pre-filter on the high flow air filter; and it has been oiled when i got it. Now I don’t know if this constricts airflow too much just yet, but when I get home I will take that off, and put in the .038 jet instead of stock
I’ll get pictures up shortly In a few hours if it helps
