Old 03-31-2019, 11:10 AM
vidaliaman vidaliaman is offline
Default chain size question
my sprocket on my axle is 1/4" thick and 1/2" from tip of tooth to tip of tooth or maybe just a hair wider, also 1' in diameter, what chain size do i have, i'm looking for the sprocket for the jack shaft and wanna make sure i'm dealing with apples to apples, thanks
Old 03-31-2019, 12:05 PM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is offline
Road Hazard
It should be a 41 chain.
Old 03-31-2019, 12:47 PM
are 40 and 41 interchangeable?
thanks j.s.
Old 03-31-2019, 02:47 PM
Functional Artist's Avatar
IIRC besides being lighter duty, #41 chain is a little bit narrower.
...so, #40 chain should work on both #40 & #41 sprockets
...but, #41 chain may be too narrow to be used on a #40 sprocket.
Here are the actual specs:
Chain Size #40-1 Pitch 0.500" Roller Width 0.312" Roller Diameter 0.312" Overall Width 0.642" Plate Height 0.475" Plate Thickness 0.058" Pin Diameter 0.156" Ultimate Strength 3,970 LBS Weight per foot 0.42 LBS
Chain Size #41-1 Pitch 0.500" Roller Width 0.250" Roller Diameter 0.306" Overall Width 0.522" Plate Height 0.390" Plate Thickness 0.050" Pin Diameter 0.141" Ultimate Strength 2,760 LBS Weight per foot 0.28 LBS
Here is a nice chart with lots of info on chain size
https://www.usarollerchain.com/rolle...art-s/4869.htm
RESISTANCE IS FUTILE
Old 04-02-2019, 02:52 PM
well i bought a sprocket (2 1/8 diameter) for the jack shaft with a 1/2" pitch, three teeth of the sprocket fit in the chain but the teeth outside of that where too far for the chain
here are my chain stats
pitch 1/2"
roller diameter 5/16
roller width 1/4"
pin diameter - between 1/8 and 3/16
link plate height - 7/16"
connecting width - 9/16"
not measured with caliper,
would you say i have a #41?
thanks
