Old 01-09-2011, 01:24 AM
sideways's Avatar
sideways sideways is offline
Unfinished projects king.
Default Tubing Notcher DIY Method
Have a look here.
Type in the dimensions, print out the PDF you then get, make sure it's 1:1 scale. Cut the template out.
Tape it onto the tube.
Trace the outline.
Grab an angle grinder (called sawz all in America?) with a cutting disk and and a grinding disk, or even better, a flap wheel. Cut it back to the line with the cutting disk first.
Then tidy it up with the flap wheel or grinding disk.
Perfect!
Nice and square too.
Brilliant idea isn't it? I know I'l be using this a lot in the shed! Even better, it costs basically nothing!
*Pics and general idea nicked off another forum*
Thanks
Hayden
The Following 17 Users Say Thank You to sideways For This Useful Post:
2SlickNick (08-07-2016), 3kakr4 (10-22-2016), AltuveRules (10-05-2016), bighead (01-09-2011), Cam (01-09-2011), Doc Sprocket (01-09-2011), Functional Artist (08-20-2016), jroberts (06-24-2014), karte_m0lim (08-06-2014), kenworth85 (01-01-2017), olliecracker (08-16-2011), Oxymoron (10-18-2013), robertdjung (01-09-2011), T.Blincoe (04-01-2015), tractor guy (10-31-2013), txluke (03-05-2019), zogthegreat (03-07-2017)
Old 01-09-2011, 01:33 AM
Cam's Avatar
Cam Cam is offline
Nz Petrolhead
Makes a clean fish mouth, although i would still tack it with the square in place.
I do a lot of this tubing, in and out of work, and after a while your fish mouth joints can be pretty precise, and i spend a lot of time on mine, my old man used to say just tickle the end to suit, shove the square/magnet on it and tack er up, but i like mine to look professional, like the joint above.
A lot of these small tips could do with being brought up.
Cheers, Cam.
Old 01-09-2011, 10:04 AM
sideways's Avatar
Originally Posted by redsox985 View Post
How do you make the templates? (possibly a stupid question...)
Go to the link in the first line of my post, type in the variables and print the PDF you will then receive.
Thanks
Hayden
Old 01-09-2011, 09:08 PM
redsox985's Avatar
redsox985 redsox985 is offline
Simple enough! I like the idea.
Old 11-22-2011, 08:41 PM
oldbikerarlo's Avatar
oldbikerarlo oldbikerarlo is offline
Old guy
Used this last week works great. even 10* angles and two differant sizes
I have a cut off saw, and a welder, anything will fit.
Old 11-25-2011, 06:43 AM
Scout's Avatar
Scout Scout is offline
Nutjob
chop saw notching
http://pirate4x4.com/tech/billavista/Links/
Old 05-15-2012, 08:10 PM
Doc Sprocket's Avatar
FWIW, I just used this for the first time with total success- had a tricky one to figure out and it ended up being pretty painless...
Old 02-06-2015, 05:29 PM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
Another link to this:
Dan Hopper's TUBEFIT Program
Dan Hopper has written a standalone program called Tubefit that gives the same result as the Coping Calculator, when "straight in" is selected. In addition it can also calculate a template for a "straight across" cut which automatically makes a fillet for welding. The latest version is capable of making very large templates if you are willing to do some manual editing of the disc output file. Dan explains how to do this in a text file included in the download. Tubefit also gives you the option to rotate the intersection of the two tubes.
Tubefit is actually a DOS program, but it runs fine on WindowsXP. It can send a postscript file directly to the screen, to a parallel printer, or to a file. This file (postscript or .ps) can then be edited if necessary and sent to any printer.
TUBEFIT.zip (last updated 9/13/08)
readme
Derivation of Dan Hopper's TUBEFIT Algorithm
NOTE FROM ROBERT -- NO IDEA IF THIS STILL WORKS BUT FYI!
