Old 07-31-2014, 09:07 PM
OzFab's Avatar
OzFab OzFab is offline
Default Drive Ratios For Dummies (Gearing)
The first thing you need to know is
Low ratio number (eg: 2:1) = high gear = high speed
High ratio number (eg: 12:1) = low gear = low speed
Lets say you have a 12 tooth clutch on your engine & a 72 tooth sprocket on the axle, that gives you a drive ratio of 6:1.
How did I get that? by dividing the number of teeth on the axle sprocket by the number of teeth on the clutch sprocket: 72/12=6
The drive ratio determines your top speed, as well as the amount of torque available for acceleration & there must be a compromised balance between the two...
For example, if you use a 4:1 ratio (regardless of other factors) it will have a huge top speed but, you will destroy any clutch attempting to reach it; likewise, if you have a 12:1 ratio, acceleration power will be excellent but, top speed will be lousy...
There are many of variables to consider when deciding on a drive ratio:
-kart size & weight
-engine capacity/output
-tyre size
-transmission type
All these variables must be considered before making a final decision...
A 6:1 ratio is perfect for a small kart with 13" tyres, a 6.5hp engine & a centrifugal clutch but, would be useless on a buggy with 22" tyres; for that you would need a much lower gear ratio…
So, why can’t I have a 6:1 ratio on my buggy with 22” tyres?
You can, if you want to burn out a clutch every 10 minutes…
As mentioned,
So, now look at the size difference in the tyres; 22” is almost double 13” so, you must use a lower ratio to compensate…
Quickly, just go & punch the following numbers into our speed calculator
Diameter in Inches: 13
Engine RPM: 3600
Teeth on Axle: 6
Teeth on Clutch: 1
Then hit the Convert button…
The number that appears in the MPH box should be 23; that is the estimated top speed of a kart with the above specs…
Now, go back & change just the Diameter in Inches to 22 & hit the Convert button; the number in the MPH box should now be 39.
You see, by changing the height of the tyres, you change the estimated top speed. Why? Because you changed the overall drive ratio; now go back to the calculator again & change the Teeth on Axle number until the MPH gets close to 23; what did you end up with?
So, isn’t a higher top speed better?
No! Whatever you add to top speed, you take away from acceleration; here’s the compromised balance I mentioned earlier…
By having a gear ratio that achieves a high top speed, you add unnecessary pressure to the clutch. Torque is what’s needed to get the kart moving; if the torque output of the engine is lower than the torque needed to move the kart, the clutch will suffer. The easiest way to overcome this problem is to adjust the drive ratio, usually by increasing the size of the axle sprocket…
I have a 3hp engine & 20” wheels on my kart; will a 6:1 ratio work?
Without considering any other aspects, the only thing guaranteed to happen with such a setup is the destruction of the clutch; let me explain why:
Torque! Torque = turning effort
A 3hp engine with a governed max RPM of 3600 will produce a maximum of 4.38 ft/lbs of torque
A 6.5hp engine with a governed max RPM of 3600 will produce a maximum of 9.48 ft/lbs of torque
The axle sprocket:engine sprocket ratio then acts as a torque multiplier, the tyres then act as a torque reducer
What does that mean? Let me explain:
Let’s say you have 6:1 gearing (12 tooth clutch & a 72 tooth axle sprocket), a 6.5hp engine & 13” rear tyres:
To find the available torque at the wheels, first you need to multiply the engine torque by the drive ratio:
9.48x6=56.88 ft/lbs
Now we need to find the ratio between the axle sprocket & the tyre; a 72 tooth #35 sprocket has an outside diameter of 8;814” so
13” tyre divided by 8;814” sprocket = 1.475
Now we divide the axle sprocket torque by the axle sprocket/tyre ratio:
56.88/1.475 which gives us 38.56ft/lbs of torque at the rear wheels.
So, what we you change only the tyre size to 20”; what happens then?
20” tyre divided by 8;814” sprocket = 2.27
56.88/2.27 gives us 25.05ft/lbs of torque at the rear wheels.
So, what do you think will happen if, between the weight of the kart & the rider, a minimum of 30ft/lbs is required just to [I]move[/] it? The short answer is you’ll destroy the clutch…
Back to the original question, if you use a 3hp engine in place of a 6.5hp, 6:1 gearing & 20” tyres, you’ll end up with 11.58ft/lbs at the rear wheels
I have a 12 tooth clutch & I need a drive ratio of 9:1 but, I can't find a 108 tooth axle sprocket…
This is a common problem; the only way to remedy it is to incorporate a jackshaft
What is a jackshaft?
It’s literally a shaft that hold 2 bearings & 2 sprockets that allow you to add compound gearing to the drive line, providing a much larger range of ratios. The two bearings are anchored to the kart frame so that the two sprockets are aligned with the clutch & axle sprockets...
Let’s look at the example above; you have a 12 tooth clutch on the engine & a 72 tooth sprocket on the axle but, you’ve decided to change the 13” tyres for much larger 22” tyres, now you need a 9:1 drive ratio to compensate for the larger tyres…
So, the current drive ratio is 6:1; what size sprockets will you need to achieve 9:1? Well, there’s no “magic number,” you just have to play with numbers until you find the correct ones…
There are many online calculators such as AGKs, Comp Go Parts & Burris Racing that will simply spit numbers out but, I’m going to show you how they work.
Ok so, let’s start at the axle & work back: So, the axle sprocket (A/S) has 72 teeth; to make life simple, let’s put a 12t(ooth) sprocket on the output end of the jackshaft (J/S out); now, just for examples sake, for now, we’ll put another 12t sprocket on the input end of the jackshaft (J/S in). With that configuration, I can tell you the drive ratio is still 6:1.
How do I know that? Well, for starters, the two sprockets on the J/S cancel each other out because they’re the same size but, also because I used a formula to figure it out:
First, divide A/S / J/S out (72/12=6)
Then divide J/S in / C/S (clutch sprocket) (12/12=1)
Now multiply the two numbers together (6*1=6)
Well, that didn’t change anything so, lets increase the size of the J/S in sprocket to 24t & see what happens:
J/S in / C/S (24/12=2)
6*2=12
Ok, now that’s too low so, let’s split the difference & use an 18t:
J/S in / C/S (18/12=1.5)
6*1.5=9
So, you see how we have to play with the numbers to find the desired result? And that was a simple one…
With a jackshaft, you can use smaller sprockets to achieve the same ratio as what you would use if you just have a clutch and axle sprocket. A jackshaft is often used because there is either no ground clearance, a large ratio is needed or if you are using a Torque Converter
More to come...
The Following 31 Users Say Thank You to OzFab For This Useful Post:
cbake (06-18-2016), chancer (05-26-2015), Chevyman1987 (01-21-2016), davidbooth1991 (08-23-2014), fastbooger (03-17-2015), firemanjim (08-01-2014), gregm001 (09-03-2014), Griff726 (04-27-2015), harrisonk (01-31-2016), Hellion (10-13-2017), Hursty (03-12-2015), Improviser (07-03-2017), itsid (08-01-2014), Joe-405 (09-30-2014), Josephmarius (06-12-2017), landuse (08-01-2014), leesiel (02-08-2017), lilg111111 (08-01-2014), lyfesaver (10-27-2014), machinist@large (09-29-2014), Matisse27 (03-05-2015), mckutzy (10-23-2015), michaelcorp (02-02-2016), Monsterhobby (05-09-2019), MOPARVICK (12-19-2015), nick956 (08-01-2014), nixta (10-12-2014), Tigerboy2009 (07-13-2017), Trayin (06-01-2018), ul3m8 (01-14-2019), ultralight01 (06-16-2016)
Old 07-31-2014, 09:25 PM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
I only want to add that this should be a sticky, in BOLD TYPE lettering. This is about as easy as it gets, in explanation....
O yeah, I would change /add 2 words.... Higher number OF TEETH, lower number..... Just to be super clear about WHAT number.....
Other than that.... (I'm kinda liking the 2 thumbs up bit. We need a thumbs down too.... )
The Following User Says Thank You to firemanjim For This Useful Post:
Old 07-31-2014, 09:33 PM
OzFab's Avatar
I only need one more vote...
Thanks, that's what I was going for...
For clarification, I just edited what I think you're referring to...
The Following User Says Thank You to OzFab For This Useful Post:
nixta (10-12-2014)
Old 07-31-2014, 09:40 PM
firemanjim's Avatar
I'm going to second the vote too, cuz I'm good.....
Low number (of teeth)=higher gear //// high number (of teeth) =low gear
When you put "ratio" out there, is where it goes south for most people.... "what is a ratio?" See what I'm saying?
Let me rustle up a voter to third my nomination and my second.....
EDIT #2....
If you want to "play" with the numbers and see how it all correlates, try this link for jackshaft ratios...http://www.affordablegokarts.com/GearCalc.php
And this one is single ratio.....http://www.diygokarts.com/speed-calculator.html
Old 07-31-2014, 10:00 PM
OzFab's Avatar
I see what you're saying but, 144 & 24 are big numbers &, combining sprockets with those tooth counts still only gives a 6:1 ratio, which is not that big a number; see how it may get confusing?
Old 08-01-2014, 12:40 AM
landuse's Avatar
landuse landuse is offline
I would also sticky this
Tony....could you do a post here that would relate to jackshafts. The formula, how they work, etc...
I could do it, but it is your thread
Old 08-01-2014, 01:32 AM
OzFab's Avatar
I intend to but, if you want to write it up, I will add it to the main post (or you can )
Old 09-29-2014, 10:21 AM
firemanjim's Avatar
Thank you.....
Old 10-12-2014, 06:37 AM
josha907 josha907 is offline
I have a 503 dc snowmobile engine I have a 54 tooth on axle but using the chaincase from the sled how would I know what sprocket I want on jackshaft
Old 10-12-2014, 05:15 PM
OzFab's Avatar
We need more info but, let's keep it out of this thread...
  #11
Old 12-13-2014, 03:42 PM
Oddball Honda Oddball Honda is offline
Oddball Honda
Hello all. I am new here but I have a question about sprocket configuration. I weigh about 195lbs, my cart weighs about 200 lbs. Now, my question is this : if I want to outrun a cart that probably weighs in at around 100-150 lbs, the rider weighs 165 lbs. His cart has a 12 th clutch, a 60 th axle sprocket. We both have the same engine, being a Honda GC160 5hp. His cart has 4.10/3.50-4 tires on it and I have 4.10/3.50-5 on mine. I'm wondering if I go with a 19 th clutch sprocket and a 54 th axle sprocket, will that get the job done? Any help will be greatly appreciated.
  #12
Old 12-13-2014, 03:43 PM
jeeperjoel's Avatar
jeeperjoel jeeperjoel is offline
well you have the same engine, but your cart has a decently higher overall weight, distance would be the deciding factor, you could gear it low, accel faster off the line, but he'll overtake you soon after that, or you could gear it high, he'll leave you behind until max speed is reached then you'll be able to go faster, if your engine has enough torque to still hit high rpm with high gears that is.... i'd gear it down for faster accel, so you won't get left behind off the line, and out of corners, or up hills clutch 10 sprocket 60... or run a comet converter instead of centrifugal clutch 12/54 and really go!
educated guess=fact -my gpa
The Following User Says Thank You to jeeperjoel For This Useful Post:
  #13
Old 12-13-2014, 04:23 PM
OzFab's Avatar
The only thing I can guarantee happening is you will burn out your clutch:
60/12 gives you a 5:1 gear ratio, a bit high but reasonable
54/19 gives you a 2.8:1 ratio, that's instant clutch killer gearing, the kart will never move...
Interestingly enough, you would do better with a lower ratio (6:1) than a high ratio as the engine won't be working as hard &, therefore, will deliver better performance; it's all about the best use of the available torque from the engine &, right now, it would be struggling to push a 400lb load with 5:1 gearing
