Closed Thread
  #61
Old 10-05-2010, 07:48 PM
porsche930dude porsche930dude is offline
yup you dont need a electic start they were just optional for snowblowers and stuff. I see your engine even has a block off plate where the starter goes so it didnt come with one from the factory. Post a wtb ad for the pull start you shouldnt pay over 25$ for one
"When in doubt make it stout"
  #62
Old 10-05-2010, 07:58 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
well anyways guys this is more of a long term project and i figured since pretty much everything was stripped off the block i decided to just completely rebuild the thing. its all down to the block, and from here im gonna clean and wash each part, re oil and slap it back together, but i need a torque wrench first before i reassemble.
wow, ive never seen a piston that big before, i think its near 400cc
(the biggest motor ive seen the piston is a 43cc)
well i have a dremel so i can polish the intake and exhaust, clean out most of the deck and piston......
doesnt look that bad at all. i got pics but im too lazy to upload at the moment, ive been so busy with school.
  #63
Old 10-06-2010, 04:52 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Dont pollish the intake, only the exhaust.
ASE Certified
  #64
Old 10-06-2010, 06:10 PM
oscaryu1 oscaryu1 is offline
Polish the piston? Lol?
  #65
Old 10-06-2010, 07:53 PM
devino246's Avatar
Quote:
I think he meant clean the piston
ASE Certified
  #66
Old 10-06-2010, 08:01 PM
yea right, i meant polish because there are sometimes grooves dug in it. looks fine, though.
status of the engine: block totally torn down.
gonna powerwash it then see what i can do about that headbolt.
can i just buy a starter cup????
  #67
Old 10-08-2010, 09:56 PM
  #68
Old 10-09-2010, 02:19 PM
dave1701's Avatar
dave1701 dave1701 is offline
Good for 100,000 Miles
cool
  #69
Old 10-09-2010, 02:28 PM
newrider3's Avatar
newrider3 newrider3 is offline
I wouldn't use that corded drill, with the switch like that it won't have variable speeds, and turn way too fast for what you need to drill.
Don't let your keyboard write checks that your a$$ can't cash.
  #70
Old 10-09-2010, 02:50 PM
r97's Avatar
r97 r97 is offline
Measure twice cut once
yea don't use the drill, i see you got some bike free-wheels with maybe 5/8"(?) adapter hubs, i have heavly reasearched these for this thread, http://www.diygokarts.com/vb/showthread.php?t=8913
  #71
Old 10-09-2010, 04:36 PM
yup guys so today i was really happy bought a tap from the same guys who sold me the motor and guess what.
THE F*CKING TAP BROKE IN HALF FLUSH WITH THE DECK
what the hay am i going to do now???????
  #72
Old 10-09-2010, 05:29 PM
r97's Avatar
r97 r97 is offline
that sucks, go get a bolt remover kit thing(forget what its called can find you one if you want).
  #73
Old 10-09-2010, 09:38 PM
im way more ****ed than i used to be now. its even worse.
and then i put the engine up on a shelf, thats where it shall stay for a while.
  #74
Old 10-09-2010, 09:41 PM
devino246's Avatar
Sometimes the best thing you can do is walk away. Let it sit for a few days(or weeks) and come back slightly less ****ed.
ASE Certified
  #75
Old 10-10-2010, 11:35 PM
or like months in this case. i am working on 2 projects right now and i dont even have anything to put the briggs in. im gonna hopefully expand my tools enough to get a cheap drill press or even a used one. sucks my workplace is in the basement, i dont have a garage. in order to weld i will need to make ducts and ventilation and strip the floor to cement. i hope mom approves, hahaha
  #76
Old 10-11-2010, 12:20 AM
dam it i want this so bad
http://hartford.craigslist.org/for/1990613875.html
aaaahhh if i get that much money soon i have to get it
  #77
Old 10-11-2010, 02:39 AM
Cam's Avatar
Cam Cam is offline
Nz Petrolhead
You do know how to tap a hole, right?
for cleaning thread wind it in a few turns with cutting fluid - car oil/2 stroke oil/Rtd/hydraulic oil/ canola oil if ya have to! the tap needs lubrication,and you need to tak it out blow the swarf out of it and wind it in a few threads more!
When tapping a new thread drill a hole the size down then run your tap in a few turns following same principles above,
the tap is made out of high carbon steel, it doesnt flex it snaps, if you feel resistance don't just wind it on thru she'll be right!, give a a small bit of elbow back it off clean the tap more fluid try it again..
E z-out/remover kit yeah same principle applys for them as well don't go hard on them they just snap!
Hope it works out for you, sound like your in a pickle, good luck.
Cheers, Cam.
  #78
Old 10-11-2010, 09:10 AM
fowler's Avatar
fowler fowler is offline
for tapping and to avoyyed snapping i was always told to go one turn in half turn out that way it snaps the burrs u are creating by cutting the thead and the tap will last longer.
oh and as cam said cutting fluid is a nessesity, stuff like trefolex works great epesialy when u are trying to put a rusty nut on a rusty nut.
it is very useful on a farm machenery mechanics
That's not an oil leak
It's horsepower sweat
  #79
Old 10-11-2010, 10:11 AM
freakboy's Avatar
freakboy freakboy is offline
the names 'mater
Sounds like you have a cursed block....
  #80
Old 10-11-2010, 12:41 PM
yes i do. i brought it to the place i bought it from and he was like wow, you got bad luck.
Closed Thread
