Closed Thread
  #41
Old 04-07-2015, 06:55 PM
Russ2251's Avatar
Russ2251 Russ2251 is online now
Suspension? Not a GoKart!
Keep in mind that just about any air filter that fits a Tecumseh engine/carb will fit on the Tillotson HL.
Everything looks good so far. Nice work.
The clone and Predator guys are getting nervous.
https://www.youtube.com/watch?v=6NeWZQ_MFsE
  #42
Old 04-07-2015, 07:18 PM
rushking19's Avatar
rushking19 rushking19 is offline
OMG That Thing Looks So Bad, Good Work, I Love Lawnboy Duraforce Engines, I Just Love 2 Strokes,I Can Wait To Hear This Thing Run, In Action
It's Fast ,But Needs One More Cylinder
  #43
Old 04-07-2015, 07:24 PM
rushking19's Avatar
I Know Clone And Predator Guys Are Terrified By My Motor
  #44
Old 04-08-2015, 05:54 AM
Russ2251's Avatar
Quote:
Im all for maximum performance out of this engine but I think I will stick to stock steel reeds.
Turns out I have an extra set of carbon fiber reeds...hand made by humble self.
Just needs 1 hole drilled for mounting. Are you interested?
Just PM me with your address and I'll mail it to you gratis.
Let me know what you want to do.
  #45
Old 04-08-2015, 06:09 AM
Rear engine 86's Avatar
Rear engine 86 Rear engine 86 is offline
After looking at pics of your dual engine kart I finally clued in that your using the Tecumseh minibike specific air cleaners lol.
I'm thinking I will run a billet air filter adapter with a clamp on all foam air cleaner so I can get my Tav angled closer to the horizontal position. If the jackshaft bearing section hits the foam air filter and compresses it abit, I'm ok with that.
Hahah...yes Russ I bet they are and I feel the same about clone OHV engines
as yourself.
  #46
Old 04-08-2015, 06:13 AM
Quote:
Thanks man and you and I both!
I'm a huge fan of 2 cycle engines myself too and I have always wanted a large bore, big displacement 2 smoker on my minibikes or karts, just like back in the day.
  #47
Old 04-08-2015, 06:14 AM
Desertduler Desertduler is offline
Not to jack your thread Rear Engine 86, carbon fiber reeds are way more responsive than steel reeds and steel reeds can be very destructive to an engine when they break and go through a engine, not good! I would take the offer from Russ. Don't be a clone!
  #48
Old 04-08-2015, 06:17 AM
Hey that would be great Russ and thanks a million!
I'm a lil nervous drilling the extra hole due to the carbon fraying.
Should I just put a dab of CA glue where I drilled the hole?
PM sent and thanks again
  #49
Old 04-08-2015, 06:23 AM
Quote:
Oh no hey no worries there lol. Internet things like that dont really bother me
I will most deffinatly be taking Russ up on his offer and if this means even more performance, with abit of a saftey net than Im diggin this mod for sure.
My biggest concern is the reed screws backing out and tossin a wrench in the works! Loctite 271 it is...
  #50
Old 04-08-2015, 06:32 AM
With the threads clean and or primed the 271 will not let you down.
  #51
Old 04-08-2015, 06:40 AM
What engine do you run in your kart?
  #52
Old 04-08-2015, 06:44 AM
Good to know and I need to find this and Loctite 320 lapping compound to finish my head and block locally somewhere.
Do you think a piece of granite tile from a hardware store will work for a flat true surface?
  #53
Old 04-08-2015, 07:02 AM
Russ2251's Avatar
PM received.
Will try to send out today or by the end of the week.
  #54
Old 04-08-2015, 07:07 AM
I use plate glass and I have had good results, make sure to move the object that you are lapping in a figure 8 pattern, a lapping block is the best thing to use but not everyone has access to one, I also use my lathe to reduce most of the material that I remove from cylinder heads to adjust the squish band and then finish lapping the surface smooth. I would say no to the tile. What ever Russ has done with his engine I would follow his advice, We are talking about different engines and procedures here. Maybe he has lapped the cylinder and head together?
  #55
Old 04-08-2015, 07:19 AM
I will go with the plate glass and still trying to find 320 lapping paste somewhere locally here in town.
I'm starting to wonder if there is anything else I could use for lapping compound besides Loctite 320?
  #56
Old 04-08-2015, 07:20 AM
PM received.
Thanks Russ
  #57
Old 04-08-2015, 07:39 AM
This is just water based lapping compound, I use this for lapping and it works for me.
  #58
Old 04-08-2015, 08:01 AM
I have put screw holes in reed petals before by finding a piece of small diameter steel tubing and sharpen the edge of the tubing and making a hole punch this way and I have punched out the mounting screw holes this way on my old Husqvarna race bikes.
  #59
Old 04-08-2015, 08:59 AM
Russ2251's Avatar
Not to worry...
That area of reed is covered by small rectangular retainer plate. No need to do anything.
  #60
Old 04-08-2015, 09:22 AM
Himm maybe this will be easier to find.
Closed Thread
