Closed Thread
  #81
Old 03-05-2011, 07:10 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
funny, im scared to use (my) paintball gun since last time i used it a metal piece shot out the back and fired into my wall in my room. well i sold it to my friend for $10, he rebuilt it and another piece backfired lol.
ever see that thousand ways to die episode where the kids paintball tank threads strip out and it fires off into his friend and smacks his face and he dies. lol.
i loose parts all the time too! especially tools.
  #82
Old 03-05-2011, 07:15 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
haha its like, where the **** is that wrench, what the **** whered it go, wait, is it over there, no, what the ****, oh there it is, good tool, dont you ever run away again, 5 mins. later, what the ****, where in the **** is that wrench? 1/2 wrench, come back to me
  #83
Old 03-05-2011, 07:19 PM
Doc Sprocket's Avatar
You really need to get organized!!! That would drive me insane! Clean workbench, containers for parts, ziploc baggies and a sharpie marker for fasteners and small parts...
  #84
Old 03-05-2011, 07:27 PM
kendelrk's Avatar
redneck engineer
its not that its un organized, its all in the toolboxes, its all there, its just i dont know the drawers for thesse tool boxes. and usually i loose them from running back and forth for things
  #85
Old 03-05-2011, 11:06 PM
fowler's Avatar
fowler fowler is offline
i hate it when u drop a rag on a bolt then kill your self looking
out of intrest how much si a game of paintball in the us
iv been 3 times
it costs about $120 for gear hire and entry
then i used about 300 paint balls and that sets me back $150
iv only been 3 times and spent about $810
but would i go again
**** yeah it is soo much fun
That's not an oil leak
It's horsepower sweat
  #86
Old 03-06-2011, 06:07 AM
scooterman675 scooterman675 is offline
we go to wasaga and you can get some pretty good deals there, buy 2000 paint balls get free Co2. but you have a 80 oz tank so your basically set for a good while, no matter how much of a trigger finger you are
  #87
Old 03-06-2011, 10:08 AM
kendelrk's Avatar
redneck engineer
well i cant find the stock linkage, because im terrible t keeping important things, and i absolutley dont want to take the governor out, i have taken better pictures so maybe you guys can help me figure out somthing,the last 3 pictures are of the bike itself,and the 4, show the governor arm, the throttle on the carb, and all the springs attached, i know theyre still terrible quailty, but thanks for all the help,
  #88
Old 03-06-2011, 10:10 AM
kendelrk's Avatar
redneck engineer
well there all out of configuration, the first, second, sixth and 7th are of the linkage, and 3-5 is of the bike itself
  #89
Old 03-06-2011, 11:37 AM
You have two choices. Put at all back to stock, and I do mean ALL, our tear out the governor completely. Period. There is not bubblegumming, duct-taping, jury-rigging, or McGyvering this thing. The governor will not function correctly if there's parts of the assembly missing or incorrectly connected, so you might just as well rip it out. If you do not rip it out, there's a chance that either one if the internals will let go causing catastrophic engine damage, or the arm could swivel over and hit the crank, also causing catastrophic engine damage.
Since the governor can no longer control the carb properly, it's existence is dead pointless. Either source the correct parts or remove it like a tumour.
  #90
Old 03-06-2011, 12:31 PM
kendelrk's Avatar
redneck engineer
ive found, the throttle plate, and the governor arm, which was great for me, now theres only one problem remaining, i cant find the 2 bolts for the throttle plate, or the spacers, for the throttle arm
  #91
Old 03-06-2011, 04:03 PM
kendelrk's Avatar
redneck engineer
well found a way and got everything back to stock , used some diffrent bolts, and spacers, but stock, it appears that it holds the engine at half throttle, to keep as idle, and then full when you pull the throttle arm back
  #92
Old 03-06-2011, 04:10 PM
Quote:
I have absolutely no idea what you mean. Half throttle is not idle.
Now, did you follow the instructions in the service manual to properly set the governor up?
  #93
Old 03-06-2011, 04:11 PM
kendelrk's Avatar
redneck engineer
i did, but the stock configuration of the linkage keeps the governor at half throttle
  #94
Old 03-06-2011, 04:12 PM
You mean the carb. The governor is inside the engine block.
  #95
Old 03-06-2011, 04:40 PM
kendelrk's Avatar
redneck engineer
exactley. a little mixed up, the carb throttle, is set to half, with the stock configuration, and when you pull the throttle arm, it goes to full
  #96
Old 03-06-2011, 04:42 PM
If you have everything connected and set up correctly, go ahead and try to start it. Or have you?
  #97
Old 03-06-2011, 06:06 PM
kendelrk's Avatar
redneck engineer
i have not, mom called me in, wont let me outside till tommarow, so im going to try tommarow after school, did i mention how much i ****ing hate school?
  #98
Old 03-06-2011, 06:15 PM
Enjoy it. Work sucks worse.
  #99
Old 03-06-2011, 06:58 PM
kendelrk's Avatar
redneck engineer
not if you love your job,
  #100
Old 03-06-2011, 06:59 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Just wait till you hit high school...
ASE Certified
Closed Thread
