  #21
Old 01-11-2011, 05:16 PM
Blazkowiez's Avatar
Blazkowiez Blazkowiez is offline
Kart Aficionado
That flywheel business is pretty crazy! I have yet to see one break under any circumstance.
gokartrepair.com. Family owned and operated in Houston for 40 years. Parts-Service-Advice
The Following User Says Thank You to Blazkowiez For This Useful Post:
Russ2251 (01-11-2011)
  #22
Old 01-11-2011, 05:49 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
I got tired of arguing about it.
I fear flying more...or getting struck by lightening...
Much better chance of winning Power Ball than witnessing a flywheel explosion.
Someone is making mucho dinero on this billet flywheel crap...all based on an unfounded fear.
https://www.youtube.com/watch?v=c4jch0puM1A
  #23
Old 01-11-2011, 07:56 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
Didnt they say it was hitting 9000 rpm or something? Thats more than my 2 strokes.
  #24
Old 01-11-2011, 09:18 PM
redsox985's Avatar
redsox985 redsox985 is offline
Sideways, I can't wait to see that bike!
  #25
Old 01-12-2011, 11:55 AM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
Haha interesting that there is no evidence. I agree with most people, the ones that go are the ones that are abused, and revving at 7,000+ rpm.
Rob
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
  #26
Old 01-12-2011, 12:11 PM
robbie robbie is offline
It makes me wonder if they are beating the flywheel with a hammer, causing cracks. There's no good reason why a piece of cast metal should fly apart at high RPM.
  #27
Old 01-12-2011, 04:42 PM
Russ2251's Avatar
Should be able to withstand more than that...say 10,000 rpm.
  #28
Old 01-12-2011, 05:12 PM
i just removed the governor in my clone, ran it for the first time no gov today. it got going... i full throttled it and it sounded reeeeeaaalll smooth. i cant imagine the flywheel busting though. just in case... i had my friend step away from the end of the crank case and away from the blower housing... lollolol
  #29
Old 01-12-2011, 05:14 PM
Russ2251's Avatar
i full throttled it ...
Under a load I hope.
  #30
Old 01-12-2011, 05:17 PM
Doc Sprocket's Avatar
I'll second that sentiment.
  #31
Old 01-12-2011, 05:52 PM
sideways's Avatar
sideways sideways is offline
Unfinished projects king.
I know in the 1960s go kart racers would modify their Victas and get anywhere up to about 16'000 rpm out of them.
Thats with a custom made head, porting, case stuffing, big carb and a megaphone exhaust. Standard rod and cast Aluminium flywheel. On the lawnmower they originally came off they did 4000rpm.
While a few flywheel explosions did happen it was much like the clone flywheels thing, one in a million.
I think we're pretty safe, just don't treat your flywheel like crap.
Thanks
Hayden
  #32
Old 01-12-2011, 06:55 PM
uhhh... no
well you never know if the guy smashed it with a hammer or something!
the HF guy told me even if my engine is still running at the end of 2 years come and get a new one just because. well... maybe thats what happened lol.
  #33
Old 01-12-2011, 07:11 PM
Russ2251's Avatar
Never EVER full throttle an engine without a load.
You may get away with it a couple or even a few times...but why take the chance?
Putting a load on engines eases the internal harmonics.
Harmonics (for the most part) is what destroys rods.
Once the rod goes...wave goodbye to the block as well.
  #34
Old 01-12-2011, 07:13 PM
yeah... well this engine is more of my experimental engine... it will most likely blow up sooner or later. but... i have the warranty so i can always just get a brand new one.
  #35
Old 01-12-2011, 07:17 PM
Russ2251's Avatar
Maybe...sometimes warranties change. Then SOL.
Again, why take the unnecessary chance?
  #36
Old 01-12-2011, 07:22 PM
well i am seeing what different things effect the engine in what way... i pulled the governor, drilled the main jet.. messed with the linkages.. maybe ill do something to timing or throwing briggs valve springs into it.
i think im guaranteed a replacement though.
i ran it once with no load im going to get a rear wheel soon
  #37
Old 01-12-2011, 07:23 PM
...as long as whoever you return it to doesn't happen to notice it's been modified...
  #38
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
They wont replace it if they see you've modded it.
ASE Certified
  #39
Old 01-12-2011, 07:28 PM
they said no questions asked
  #40
Old 01-12-2011, 07:33 PM
That's not a question. Mods void warranties. No questions asked means stuff like, "what were you using it for?" etc.
