Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Build Logs
Reply
Old 03-30-2020, 06:53 PM
karl karl is offline
Default 2020 - Sears LT8 "Nasty Noma" Full suspension Off road
Why not , building full tubular frame with long travel suspension and big tires.
Old noma built mower, re-badge by sears
Typical stamped mower, peerless 700, chain drive
We had one growing up! Im on the right, as you can see my dad threw a 18hp twin on it, and removed the hood
For power I am using a genuine gx390, getting bored to 90mm, stroker crank 69mm, ARC rod , 306 cam 240 dur, forged flat top piston, big valve head, anyways it will be 440cc , and run about 11 to 1 compression. Should be fun.
The Following User Says Thank You to karl For This Useful Post:
landuse (03-31-2020)
Old 03-31-2020, 03:16 PM
Donor rear end removed, 08 forester
Poor Subie, 56y/o ford will tow it to the scrapyard
landuse (04-01-2020)
Old 03-31-2020, 04:03 PM
gegcorp2012's Avatar
gegcorp2012 gegcorp2012 is offline
Cool !
Whats the width on that Forrester rear end ? Is it a limited slip ?
Sent from my SM-J700T using Tapatalk
Old 03-31-2020, 07:44 PM
Quote:
Originally Posted by gegcorp2012 View Post
Cool !
Thanks, about 57-58in. I am cutting down the cv shafts , and fabricating my own double wishbone control arms.
I dont think it's limited slip, lincoln locker?
Reply
