Reply
Old 01-21-2020, 04:27 PM
Surfishaddict Surfishaddict is offline
Junior Member
Default Distance between sprocket on drive wheel and clutch sprocket
Hi name is rob I introduced myself in other section I have a bns motor 6 hp intek wonder how much chain length I should have between clutch sprocket and drive sprocket on wheel ty sits or man
Old 01-21-2020, 05:54 PM
950speed's Avatar
950speed 950speed is offline
Could we get some pictures?
And also maybe sid could combine all your questions into one thread, it’s perfectly fine to have multiple questions in one thread and we just solve one at a time
Old 01-21-2020, 06:35 PM
Junior Member
Ok sorry I'm the newbie I'll get them
---------- Post added at 07:24 PM ---------- Previous post was at 07:14 PM ----------
Yes can you tell me which oven to grab the images
---------- Post added at 07:33 PM ---------- Previous post was at 07:24 PM ----------
https://drive.google.com/file/d/1-Nf...w?usp=drivesdk
---------- Post added at 07:34 PM ---------- Previous post was at 07:33 PM ----------
https://drive.google.com/file/d/1-Vp...w?usp=drivesdk
---------- Post added at 07:35 PM ---------- Previous post was at 07:34 PM ----------
Sorry I'll learn to send pics appropriate next x
Old 01-21-2020, 09:44 PM
itsid's Avatar
itsid itsid is online now
here's a detailed description on how to post pics
well you need ~ 1/3 of the smaller sprockets teeth engaged ideally
a quarter is just about being still okay.. less and the two sprockets are considered "too close"
mostly.
too long of a chain and you want an idler sprocket to take up slack
With your setup there, that's about as ordinary of a sprocket distance as can be..
your standard 6:1 ratio sprockets (say 10 on the clutch & 60 on the axle or 12 on the clutch 72 on the axle)
will be just in the correct ballpark.
the enigne plate should be slotted to tighten the chain properly after installation.
and that's really all you need to do.
If you feel the chain itself is still too long, just remove one more link and repeat until happy
Reply
