Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 10-13-2012, 06:11 PM
set2stun set2stun is offline
Default G"irl" Kart . . My First Build
Hey everyone . . i am new to this site and really enjoying it. I have no idea why i decided to build a go kart but i did. The kart is not perfect by any means but i'm proud of it. This cart was conceptualized, engineered and welded by me. I did not use any plans but probably should have. BTW . . i'm a girl. Here's a video of my first test drive.
Take My Advice . . I Don't Use It Anyway
Old 10-13-2012, 06:21 PM
B.M.800's Avatar
B.M.800 B.M.800 is offline
TheBeal.
Nice!
Dean done this here thing to this here thing, y'all
Sorry . . i forgot to add pictures from the build. You may notice that the cart goes through an evolution and then devolution of sorts. I had to change the front end several times in order to accommodate my legs and also to fix the steering.
Old 10-13-2012, 06:29 PM
OzFab's Avatar
OzFab OzFab is offline
Nice run, it would've been better if we could hear the engine instead of the... umm... music(?) Also, you may want to think about a chain tensioner
Old 10-13-2012, 06:34 PM
Doc Sprocket's Avatar
Agreed. It's too loose. Hard to tell with the wide angle lens- did you get that freaky frontend geometry sorted out?
Old 10-13-2012, 06:37 PM
What's a chain tensioner? That's probably what i need. Also the front end geometry is still messed up. I did change it to toe in though
  #7
Old 10-13-2012, 06:43 PM
Quote:
"Chain Tensioner". That which applies tension to a chain. Probably not necessary if you slotted your engine mount holes. Either way, chain's too loose.
Toe-in should be VERY minimal. Maybe a degree. More important is caster, camber, KPI, and Ackermann. Put up some good, still images of the frontend.
  #8
Old 10-13-2012, 06:45 PM
B.M.800's Avatar
TheBeal.
A chain tensioner helps keep the slack out of a loose chain...
On a minibike.
  #9
Old 10-13-2012, 06:47 PM
OK . . its dark out now but i'll throw some pics up tomorrow. I think i'm gonna scrap this kart and build something else. I'd love to build one with some proper geometry and a true engineered plan. I'm thinking in the lines of a shifter kart. Problem is i can't find a website that sells the shifter manual transmissions or even plans on how to build one. Any suggestions of a site?
  #10
Old 10-13-2012, 06:49 PM
You're not looking for a tranny. You're looking for a motorcycle engine- which comes with a built-in tranny...
  #11
Old 10-13-2012, 06:50 PM
Thanks B.M.800 . . i think that would solve my chain problem :-)
  #12
How do you convert a motorcycle engine from a foot shifter to a stick shifter?
  #13
Old 10-13-2012, 06:55 PM
exenos's Avatar
exenos exenos is offline
Project Nut
If you look up some shifter kart builds there will be some good examples on how they create a shifter lever. I believe that there are a few shifter builds on here.
  #14
Old 10-13-2012, 06:57 PM
B.M.800's Avatar
TheBeal.
You can connect a series of linkages to the foot shifter to where your stick shifter is.
Look around here at some of the buggy builds, lots of them used a bike engine.
On of these days i plan to build a something with a bikes engine...
One of these days.
  #15
Old 10-13-2012, 07:03 PM
In short- take the shift pedal off, and re-mount it pointing straight up. Tie a linkage from there to your shift lever. That's about the simplest solution.
  #16
Old 10-14-2012, 05:32 PM
Aladinbama Aladinbama is offline
Just Learning
Nice build! Especially if it's your first.
Oh, and Nice Puppies too!
  #17
Old 10-14-2012, 06:39 PM
shakey0818 shakey0818 is offline
Are you talking about the dogs?
Speed is how fast you hit the wall....Torque is how far you push the wall after you hit it!
  #18
Old 10-14-2012, 06:55 PM
Just Learning
Quote:
Yes! My B-I-L just had to put down his yellow Lab after many years of being owned by him! The one looking at the camera kind of reminds me of Austin! RIP Buddy!
  #19
Old 10-14-2012, 07:34 PM
I believe I just soiled myself.
You have no idea just how funny that is.
  #20
Old 10-15-2012, 04:26 AM
Orange Krate's Avatar
Orange Krate Orange Krate is offline
It amazes me what short glances we take for oncoming traffic before pulling out onto roads. I know I'm guilty of it but it really shows with a helmet cam.
Nice kart!
Closed Thread
