Reply
Old 11-04-2019, 09:21 AM
Stref Stref is offline
Junior Member
Default Help with chinese wheels
Hi guys wanted to see if you all had any advice where to buy this wheel.
It is a 145/70-6. The problem im having is that i cant find the correct bolt spacing anywhere. It is a chinese build and the bolt spacing is 60 mm with a 50 mm center hole. It is a 3 hole bolt pattern any help would be appreciated.
Old 11-04-2019, 09:26 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
BMIKarts sells an adapter for Chinese wheels, but I'm not sure if it will fit yours:https://www.bmikarts.com/Conversion-...s_p_21485.html
Pic isn't working.
Here's how to post pics:http://www.diygokarts.com/vb/showthread.php?t=737
Currently Flathead-Crazed
Old 11-04-2019, 11:20 AM
Karttekk Karttekk is offline
Would something like this work? If not check & see what else they offer.
https://www.powersportsmax.com/produ...ducts_id/13814
---------- Post added at 01:20 PM ---------- Previous post was at 01:19 PM ----------
Or these
https://familyfunpowersports.com/go-...es-wheels.html
Old 11-04-2019, 01:06 PM
Junior Member
Pic of chinese go kart wheel. You can see how the rim cracked by one of the lugs. This go kart has never been off road just driven around the cul de sac.
Old 11-04-2019, 01:18 PM
If you can find a welding shop, they could probably weld up that crack and send you on your way.
Old 11-11-2019, 10:35 AM
Junior Member
So welding shop didnt work. I was wondering if i can go just with a wheel without a hub. I see wheels that have bearings on both sides and would slip right on i figured i could use a spacer to fill in the rest if needed. Ive attached some pics if someone might know what kind of chinese crap i have. I tried dearching the vin number online and had no luck
140FF0BC-20DF-4D6C-BDCC-BE0DCFA9F6F4.jpeg   73CA24FC-7A4A-44A4-8EE0-97D398960F73.jpeg
  #7
Old 11-11-2019, 11:00 AM
Looks like a Kandi Spider:https://www.bmikarts.com/Kandi-Spide...-_p_10674.html
My best advice I can give for that thing is to get rid of it and get something good and made in America. Those Chinese mini buggies are notoriously crappy quality all around.
Measure the diameter of that spindle, if it's 5/8" or 3/4", there are plenty of wheels and hubs that will fit. But more than likely, it is metric. Even so, there are still options.
I would suggest selling that one, and fixing up a go kart off CraigsList. But it's up to you.
  #8
Old 11-11-2019, 01:20 PM
Junior Member
Thanks jtspeed, thats my goal its a 5/8 “ diameter wheel hub. Going to get a wheel hub and change it out. I took off the junk engine that came with it and installed a harbor freight 6.5 predator engine. I also had a custom 60 tooth sprocket that i put on it to slow it down since the old one was a 22 tooth sprocket. Thanks to all for trying to help
  #9
Old 11-11-2019, 02:28 PM
RobertD's Avatar
RobertD RobertD is offline
Administrator
Quote:
Well a hub is the bearings, those without them are just integrated, if I understand your comment correctly. So I wouldn't see a problem neccessarily running one with a spacer, assuming you keep your eyes on it and check it periodically. I could be misunderstanding, though!
  #10
Old 11-11-2019, 02:36 PM
I have a one piece wheel like what he's talking about, where the wheel and hub are one piece, but of course the bearings can be replaced.
OP - If it's a 5/8" diameter spindle, there are TONS of hubs and bearings that will work! Hope you have fun on that thing!
Reply
