Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 06-20-2019, 06:05 PM
Cb33 Cb33 is offline
Junior Member
Default Sprocket and chain alignment for Baja mini bike
I just got a predator 212 and am trying to mount it on a Baja doodle bug, how do I make sure/check that the sprocket and chain alignment are straight?
Old 06-20-2019, 06:22 PM
mckutzy mckutzy is online now
Visually, then a straight edge long enough to touch each sprocket...
The Following User Says Thank You to mckutzy For This Useful Post:
Panhead5496 (06-21-2019)
Old 09-12-2019, 07:08 PM
madprofessor madprofessor is offline
Erased.
My entire career in HVACR lining up everything from 1/4 hp. blowers to 4mil. BTU airshacks I kept a thin metal yardstick in my truck for aligning drives. All that matters is putting an edge against the flat of your large sprocket that won't flex in the 90 degree angle. You can flex and bend your choice of guide stick all you want to snake it where you want, as long as you keep the rigid edge pressed hard against the flat side of one drive or the other.
Closed Thread
