Closed Thread
Old 08-08-2018, 02:46 PM
Tpdingo Tpdingo is offline
Default Black residue on TAV driver?
What is this black stuff(well most likely rubber deposits from the belt) and what does it mean. My bornze bushing runs very smoothly and freely but the belt doesn't seem to catch it if that helps at all. It wipes off pretty easily
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
Old 08-08-2018, 04:10 PM
Clifton's Avatar
Clifton Clifton is offline
Indeed it is belt wear, if you had a cover over it you would likely find a fine dusting of belt rubber as well, any strands fraying off the belt yet?
A number of factors can increase belt wear:
Engine size, kart + rider weight, gear ratio, rear tire size, maybe the pulleys aren't aligned with each other, incorrect belt size / belt quality (china).
Maybe you can shed some light on some of these ^
If you have the TAV with the backplate, I believe you want the 203589 belt, there are often others that are "close" to the right size that come with it.
Old 08-08-2018, 04:27 PM
anickode's Avatar
anickode anickode is online now
Yup, it's rubber goo from the belt slipping
"Well that would be a bomb."
Old 08-08-2018, 04:56 PM
Belt fraying: yes. I can tell you all the gearing is factory and provides no strain on the TAV. Maybe the last few launches I did, the belt slipped a bit?
250lbs total load
6.5HP Predator 212 stock & governed
TAV30 W/ 6:1 ratio
18" rear tires which are properly inflated
This setup shouldn't be anywhere near the top end of what a TAV30 can handle.
Here's a pic of the belt.
Old 08-08-2018, 07:39 PM
Kansaskart Kansaskart is offline
Absolutely nothing to worry over, esp as cheap as belts are. But if you Never seen it then yeah might make you wonder. When you use $100+ belts like on my atvs then you got reason for paranoia if you think somethings wrong.
Old 08-08-2018, 08:41 PM
Clifton's Avatar
Could just be normal wear, but I understand wanting to rule out any problems. I went through the same thing when I first got a TAV, in my case the belt was the wrong size and caused it to wear prematurely.
No backplate on that setup, so to rule out belt length you will have to do some measuring.
First measure the rear pulley across and see if it's the 6" or 7".
Then measure center-to-center (center of front pulley to center of rear pulley) and you can compare the result you get with this chart to give you an idea of what belt you are supposed to have.
example: if you had a 6" rear pulley and the center to center distance measures 7", you would want a belt length as close as possible to 27.36"
You could also compare it to the length of the belt you have now. (If you don't know the size of the current belt you can measure it with a piece of string running the length around the belt, then straighten it out and measure it)
If it turns out that the belt is too long or something you may be able to move the engine forward or move the rear pulley backward if it is mounted in slotted holes.
  #7
Old 08-09-2018, 05:33 AM
Its a standard MANCO 5959/203589 belt.
  #8
Old 08-09-2018, 07:53 AM
Clifton's Avatar
In that case, you can just verify you have a 6" rear pulley and that the center-to-center distance between the pulleys is right about at 7", you should be able to move the engine forward/back to adjust the distance between the pulleys.
  #9
Old 08-09-2018, 08:28 AM
Quote:
I can't. The engine and the TAV plate are fixed because they use some wierd bolts that go straight through. The TAV and motor can be moved to adjust the chain.
Closed Thread
