  #21
Old 02-01-2020, 06:38 AM
I don't think it's possible to bore these small engines out 0.08"!! The max OEM recommendation for a Briggs flattie is 0.03", and all these small engines have thin wall blocks.
I don't think you'd need to worry about overheating, because I think you'll have a hole in your cylinder before that happens.
Why 0.08"?? Is there a particular piston you want to use? Dynocams has lots of Wiseco and a few Burris pistons for sale.
Currently Flathead-Crazed
  #22
Old 02-01-2020, 11:09 PM
Mercado Mercado is offline
Well to make it 72mm you have to bore .080 thats why to get a 72x55
  #23
Old 02-02-2020, 07:59 AM
It may be a differently designed block for the 225, though.
I bet Flyinhillbilly can answer this, I'll let someone else chime in.
  #24
Old 02-02-2020, 08:31 AM
Flyinhillbilly's Avatar
The great cornholio
The 225 block is already 72mm bore, the casting all looks really nice, and I really love all of the extra bracing.
  #25
Old 02-02-2020, 09:46 AM
The great cornholio
You can see in the pictures that there really is t much flashing, or casting flaws. These blocks have a lot of extra bracing built in, and they are very much worth the $100 that they値l set you back in my opinion.
This one is slated to be a 14.5 cubic inch open motor. I知 going to do a couple of videos of the build as soon as the rest of the parts come in.
AD583D80-62D7-4567-9E5D-9BB70D41FB0A.jpg   E1EE2E05-57DC-477C-9179-F0D47FFF6E3A.jpg
  #26
Old 02-23-2020, 06:04 PM
Can i used everything from my hemi on the tili 72mm block
  #27
Old 02-23-2020, 06:43 PM
karl karl is offline
Maybe the pull starter and ignition coil , not much else
How much of the stock predator parts do you want to install in the nice block would be the question.
You can buy just the long block , link was in the first post.
https://www.gopowersports.com/225rs-...ne-long-block/
I think you missed the point , just buy the whole 225 engine or work with what you have. Impressive power output is achievable with the predator's stock bore and stroke. Reaching the point of diminishing returns on a $100 china clone is not much fun.
  #28
Old 02-25-2020, 08:15 PM
Im waiting for my new tillotson 72m block to come and make it 72x56 with a hemi head on a weld chamber and a black mamba jr cam with 1.2 rollers let see the power on this set up
---------- Post added at 09:15 PM ---------- Previous post was at 09:14 PM ----------
The 56mm its a clone crank and rod instead of the 55mm crank i wanted some thing a little diffrent
  #29
Old 02-26-2020, 07:01 AM
The great cornholio
I知 excited to get going on building mine too. I知 still waiting on the head. It should be a pretty mean little motor. I知 going with a tunnel ported warhead with 34/28 valves, billet 1.3 rockers, 2.3 super alloy stroker crank, custom ground 360 lift cam, all fed by a Clements 34mm flat slide carb. This one should be a high rpm screamer.
  #30
Old 02-26-2020, 02:13 PM
Voodoo Rufus Voodoo Rufus is offline
Another nice option available:
https://www.eccarburetors.com/EC228R...ne_p_1794.html
  #31
Old 02-26-2020, 03:47 PM
The great cornholio
Mine is going to be 238cc, so for 10cc I should’ve just bought one of those. I guarantee it would’ve been way cheaper.
Tillotson has really stepped up over the last year.
  #32
Old 02-26-2020, 04:07 PM
Originally Posted by Voodoo Rufus View Post
Woo nice built that one
  #33
Old 02-26-2020, 04:48 PM
Bansil's Avatar
Bansil Bansil is offline
You guys are crazy in a non straight jacket way!!
  #34
Old 03-23-2020, 11:27 AM
Any thoughts on this one? Cheap enough for me to pounce on for my fun karts.
https://www.eccarburetors.com/NEW-TI...ne_p_1650.html
