Old 02-02-2020, 11:56 AM
buildinthrillz buildinthrillz is offline
Default Timing
OK I have a new question I just built a predator 212 for my non-shifting shifter kart billet rod BP2 cam 26lbs springs* I know I need to put a billet fly wheel that’s next my question is at full throttle I have 54 miles an hour around 5600 RPMs and the motor cuts out doesn’t die just cut out I let off the gas slow down a bit and it picks back up but always around 5600 RPMs does this have to do with not advancing the timing yet flywheels on the way just curious as to what would cause that.
Old 02-02-2020, 06:57 PM
pearl111 pearl111 is offline
Did you disconnect the oil sensor wire?
Old 02-03-2020, 05:21 PM
KartFab's Avatar
KartFab KartFab is offline
valve float, jetting, timing, and gearing all come to mind. Test each one to see.
