Old 07-31-2018, 09:25 AM
lliberto lliberto is offline
Default I think it's to powerful now.
My 1950s era scratch built go-kart has had a number of engines over the years. As a matter of fact, I know it has had at least 4 engines but could have been more. My grandfather got this kart for my older cousins in the late 60s and I got it from them in 1977. Around 78 I installed a 3hp Briggs and recently I upgraded it to a Preditor 212. Turns out that little 212 is super powerful and the kids burned off the rear tire in a week.
Old 07-31-2018, 09:37 AM
anickode's Avatar
anickode anickode is offline
Time to make it a live axle.
"Well that would be a bomb."
Old 07-31-2018, 09:55 AM
Tpdingo Tpdingo is offline
Or a differential, a transfer case, torque converter and CV joints for AWD.
Functional Artist's Avatar
That tire was OLD
Get some new tires & let 'em try again
...if they burn that one off in a week
Yup, what he said
RESISTANCE IS FUTILE
Old 07-31-2018, 11:08 AM
mckutzy mckutzy is offline
Scrub brakes do that... They burn up tires...
A disc would be ideal(mech or hydraulic ), band brake would be more of a period styled setup...a clutch or axle drum would do...
Old 07-31-2018, 11:54 AM
True except they are literally doing burnouts with it.
---------- Post added at 11:53 AM ---------- Previous post was at 11:51 AM ----------
Don't get me started on the mods I have wanted to do to this Kart for the last 40+ years. But right now, no time for mods as they want to drive it all the time. They're not even happy with the short down time it is going to take to change the tires. ;-)
---------- Post added at 11:54 AM ---------- Previous post was at 11:53 AM ----------
If I go that far I might as well build a new one. Which, I have been considering. Then I'd add a suspension too. Oh the ideas that come flooding in ...
Old 07-31-2018, 03:31 PM
Ok, add that, suspension, a body, and a bigger motor and room for some more passengers. Eventually you overshoot the Go kart category.
lliberto (08-01-2018)
Old 07-31-2018, 04:05 PM
tgus3's Avatar
tgus3 tgus3 is offline
a member
that what i call a real gokart
Only know you love it when you let it go..
The Following User Says Thank You to tgus3 For This Useful Post:
Old 07-31-2018, 04:51 PM
*go kart hauler. That probably is awesome, just throw a huge 2 seat murray in the back like it is no tomorrow.
Old 08-01-2018, 12:55 AM
landuse's Avatar
landuse landuse is offline
Or you could just gear the kart slightly higher so that they can't do burnouts, but there is still enough low end torque for them to be happy. What is your gear ratio at the moment (sprocket tooth counts and tyre diameter will help if you aren't sure how to calculate it)?
  #11
Old 08-01-2018, 05:19 AM
itsid's Avatar
itsid itsid is online now
or if you don't want to change the sprockets, just slap on two larger rears (say 15" )
I mean you need new tyres anyways
The Following 2 Users Say Thank You to itsid For This Useful Post:
landuse (08-02-2018), lliberto (08-01-2018)
  #12
Old 08-01-2018, 06:07 AM
ezcome-ezgo's Avatar
Quick fix: swap the rear wheels
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
  #13
Old 08-01-2018, 08:00 AM
Quicker fix: Get HF tire and rims. Atleast if the kids will destroy the tire, let them destroy the ENTIRE WHEEL. Then you get the most bang for your buck.
  #14
Old 08-01-2018, 08:29 AM
lol
Maybe I should just give them the keys to the Stang then ...
  #15
Old 08-01-2018, 10:15 PM
Kansaskart Kansaskart is offline
Get some Fred Flintstone tires.
The Following User Says Thank You to Kansaskart For This Useful Post:
lliberto (08-06-2018)
  #16
Old 08-02-2018, 01:15 AM
landuse's Avatar
Larger rear tyres should do the trick
