  #21
Old 01-17-2013, 09:47 AM
GoodWComputers's Avatar
GoodWComputers GoodWComputers is offline
Aspiring Mow-Kart Owner
Originally Posted by toystory_4wd View Post
Now, all that's left is the governor gear shaft. You can leave this if you like, I opted to remove it. Partially because I make my own gaskets and removing it makes it easy to lay the cover down flat on a sheet of gasket material and trace it out.
So there's no downside to leaving the governor gear shaft in place? I will most likely buy a new head gasket, so making my own isn't an issue.
Mow-Kart Project! - http://goo.gl/JAjCC
Custom-Made Sandblasting Cabinet - http://goo.gl/P5uBB
  #22
Old 01-17-2013, 05:04 PM
jujupope jujupope is offline
Yes the engine blew up. This thread is several months old. :-)
  #23
Old 01-17-2013, 07:03 PM
You just joined and that was your first post. How would you know?
  #24
Old 01-17-2013, 07:27 PM
OzFab's Avatar
OzFab OzFab is offline
It's also an educational sticky thread. Good to see you know the rules though
  #25
Old 01-17-2013, 07:57 PM
Doc Sprocket's Avatar
It's not the head gasket in question, it's the side cover gasket. And yes- feel free to leave the shaft in.
  #26
Old 01-17-2013, 08:33 PM
Sorry, had the two gaskets mixed up. That's great news about the governor shaft - I don't want to have to worry about tapping threads to install a bolt in place of it. Looking forward to doing this! Thanks again for the info.
  #27
Old 01-18-2013, 12:21 AM
landuse's Avatar
landuse landuse is offline
Have a look at the top left of each post. You can see the date and time that it was posted. Thats how he knew the thread was old.
We usually don't mind people ressurecting Sticky threads is the have something constructive to add to the topic, but if you are just posting to say "Great!!", we frown on that
  #28
Old 01-18-2013, 01:01 PM
I knew that, I meant how did he know that the engines were blown up? I was asking a question. I'm new to this forum myself, just thrown off a bit by someone else coming in and hatin' on me with their first post...
I completely agree. I used to be on a Mustang forum where I was long-time member like yourself. I posted in this thread with some questions.
  #29
Old 01-18-2013, 04:29 PM
You, and me both. Trust me- If I had an issue with you posting in this thread, I'd let you know. I don't. As fer the other guy... looking rather trollish so far.
  #30
Old 01-22-2013, 11:07 AM
Once I tear apart the engine and remove the governor, what is the recommended procedure for throttle hookup? I've been searching around the forums and want to make sure I do the correct thing with my setup.
I've come to believe (please correct me if I'm wrong, I'm trying to educate myself about this stuff) that my carburetor has a throttle linkage and a governor linkage. It has two butterfly plates on the inside. Once I remove the internal governor in the engine, I just remove the governor linkage. Is that it? Do I just leave the butterfly as is, or remove it? Or do I move the throttle linkage to the governor linkage location? See pictures below.
  #31
Old 01-22-2013, 04:22 PM
Not quite. The butterfly closest to the engine is the throttle plate. The outer one is the choke. Leave the choke as it is. Once you remove the governor, remove ALL associated hardware and linkages, up to that throttle plate. Now, you will connect the throttle cable from your gas pedal directly to that throttle plate arm.
The Following User Says Thank You to Doc Sprocket For This Useful Post:
GoodWComputers (01-22-2013)
  #32
Old 01-22-2013, 04:49 PM
Thank you! Finally a clear and concise statement that makes everything I've read so far make sense.
  #33
Old 01-22-2013, 05:43 PM
I accept cash, money order (both CPS and USPS), certified cheque, PayPal, e-trasnfer.... LOL- Just kidding- you're welcome!
  #34
Old 01-22-2013, 06:43 PM
So the choke butterfly will stay permanently open? Will I ever need to use it again?
I haven't been on here a while but I can already tell how useful you are. I'll spread the word that we should keep 'ya around... lol.
  #35
Old 01-22-2013, 07:04 PM
Yes- use it normally. Close the choke for cold starts, and re-open after it warms a bit.
Please do!
