Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes and Choppers
  #21
Old 09-24-2012, 04:44 PM
tundrabeagle3's Avatar
tundrabeagle3 tundrabeagle3 is offline
i got the jackshaft kit on and it works great the chains are very short.
edit: just tried it offroad and it never fell off once
  #22
Old 10-01-2012, 06:21 AM
Sam-Q Sam-Q is offline
pics of new set up?
  #23
Old 10-01-2012, 02:15 PM
heres some pics. I tack welded the bearing flanges , and swapped my #41 chain for #40 chain after it got kinked up.
  #24
Old 10-01-2012, 03:14 PM
I don't want to sound negative but it sounds like a lack of maintenance ot me. A chain shouldn't get tight links unless it runs out of lubricant and then bind up.
Having a jack shaft will help control your chain slop but shouldn't reduce the stress on it.
  #25
Old 10-01-2012, 03:54 PM
i believe the chains kink up from the doing the sharp angles and the stress of the abuse i give my mini bike. I have had no kinking problems with the heavier 40 chain on my mini bike or the 520 chain on my dirt bike.
  #26
Old 10-01-2012, 03:56 PM
I see, what size cog are you using on the engine?
  #27
Old 10-01-2012, 04:02 PM
im using a 12 tooth sprocket and a 72 tooth rear sprocket. the jackshaft has two ten tooth sprocket so i can have a good mix of torque and top end. it has a 6:1 ratio and i ride it at 40 mph over dirt roads with potholes, large rocks, ruts ect and i also ride it at a pitbike track with some small jumps ect.
  #28
Old 10-01-2012, 04:15 PM
would that not put more stress on your chain again because it's going around an even tighter bend?
Do you have a worklog for this? sounds interesting
  #29
Old 10-01-2012, 08:50 PM
not sure what you mean?
i have a few pics of my old setup if you want to see it.
  #30
Old 10-01-2012, 09:08 PM
a worklog, as in a build diary.
But yes sure any pictures would be good
  #31
Old 10-02-2012, 12:25 AM
that's really neat, looks like lots of fun
  #32
Old 10-02-2012, 12:39 AM
landuse's Avatar
landuse landuse is offline
Originally Posted by tundrabeagle3 View Post
I tack welded the bearing flanges.....
Make sure that you do more than tack weld those flanges. With the stress you are putting on them, they had better be rock solid
Last Build: http://www.diygokarts.com/vb/showthread.php?t=11334
We are what we repeatedly do. Excellence, therefore, is not an act but a habit-Aristotle
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
