Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 07-27-2008, 04:14 PM
847 847 is offline
big pimpin
Default what kind of 2 cycle is this?
i'll get pics up when my cam works
on the carb is says "w18a" under that it says "54". on the bottom it says"zama" from what i can tell it's a c1u. but that means nothing as i dunno what it goes to.
on the engine it says 3453 lot c, then over more it says 530-012581 rev b. and on the casting by the intake it says 12519.
the flywheel says 15-567 "walbro "
the coil says 545-024901 then below that it says ma-73 1235 "walbro"
and the plug is a rcj6y
Old 07-27-2008, 04:53 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
The cheap kind.
25cc Poulan Weedeater
Those that can...do. Those that can't...buy a predator.
Old 07-27-2008, 09:20 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Quote:
Originally Posted by Russ2251 View Post
The cheap kind.
They are cheap but they can take serious abuse.
Old 07-27-2008, 09:23 PM
847 847 is offline
big pimpin
well, can i upgrade it? i have a walbro wt-312 carb ... not sure how good that is. but yea, it's way bigger, diameter wise. can i put the regular x-tube on it? was also wondering if my stock carb would take a volocety stack, or if the 312 worked, if i could find a stack for that.
Old 07-27-2008, 10:46 PM
Kartless....
Your not gonna find performance parts for a weadeater, run it without the muffler and put a bigger air filter on it. maybe port it out.
Old 07-27-2008, 11:01 PM
847 847 is offline
big pimpin
well, i figured the spacing would be around the same for the x-port. but if not, yea putting a hole in the muffler. goin' to try out tomorrow or in a few days about the walbro carb. i think i may need some ether for this one tried it tonight, seems to flood the crap out of the cylinder.
  #7
Old 07-28-2008, 01:18 AM
Kartless....
Quote:
Sounds over carbed, probably gonna need adjustment.
The Following User Says Thank You to Kenny_McCormic For This Useful Post:
847 (07-28-2008)
  #8
Old 07-28-2008, 07:12 PM
847 847 is offline
big pimpin
can you reccomend? also which way is correct for ignition? i tried clock wise and counter clock wise... got a few pops on counter clock wise .. i think? how many turns in on high and low needle? thanx
also, clock wise, the muffler was on the left, using forward on a drill, counter clockwise was reverse on the drill.
  #9
Old 07-28-2008, 07:41 PM
847 847 is offline
big pimpin
also where can i get the rear sprocket that bolts onto the bikes back tire? does it need an adapter?
edit -
you really think a x port won't work?
http://www.gomeyer.com/rc-cars-scoot...-lg-p-204.html
it has 23-29cc engines listed .. what's the diff? the bolt pattern/width?
Closed Thread
