Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 06-12-2011, 07:09 PM
Joeyk99 Joeyk99 is offline
Junior Member
Default What's a jackshaft??????
I was looking at a torque converter and it said that it replaced a jackshaft and I have no idea what that is can someone help me!!!!???
Old 06-12-2011, 07:57 PM
mckutzy mckutzy is offline
It is used to change the plane of drive, typically with a motor to have a right side drive. on mine this is what I did. In this pic the guard wasn't fully atached yet.
Old 06-12-2011, 08:15 PM
Doc Sprocket's Avatar
In addition-
They are often used to create a gear reduction ratio that would be impossible or impractical without. For example, a 10:1 ratio can be reached with a 10T engine sprocket and a 100T axle sprocket. But that axle sprocket would be huge! The tire wouldn't touch the ground because of it. So- jackshaft. 10T on the engine and 20T on the "in" side of the jackshaft. Then a 10T on the "out" side of the jackshaft to a 50T on the axle. Same overall ratio, axle sprocket is half the size.
Jackshafts can also be used to go from belt to chain drive or vise-versa.
The Following 2 Users Say Thank You to Doc Sprocket For This Useful Post:
Big Boy (06-12-2011), wooley (06-12-2011)
Old 06-12-2011, 09:02 PM
oh ya I forgot to mention those aswell, definitely on changing gear ratio is much easier. just swap the sprocket out for the right one.
Old 06-12-2011, 09:10 PM
Junior Member
and also how does a torque converter work/what does it do/how does it connect with the driveshaft and chain??
Old 06-12-2011, 09:38 PM
It is a type of CVT(Continuously variable transmission) http://en.wikipedia.org/wiki/Continu...e_transmission
it is an " clutch-less automatic transmission" if u will. it can be chain or belt like in a snow or other type machine.
  #7
Old 06-13-2011, 12:56 AM
bighead's Avatar
bighead bighead is offline
Attention Criminals!! This is a defense free crime zone. All law-abiding citizens have been disarmed for your convenience.
  #8
Old 06-13-2011, 01:11 AM
B man's Avatar
B man B man is offline
Tecumseh FTW!
^^still pointless lol.
If it doesn't work......well then its gonna!
  #9
Old 06-13-2011, 01:45 AM
bighead's Avatar
Quote:
What is so pointless? Can you not figure out we are not talking about an electric motor but how a TC works? Hello, Mcfly!
If this make you feel better then here you go.
Closed Thread
