Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 04-05-2011, 08:30 PM
jk95ht jk95ht is offline
Default what to strip 49cc mini bike
i have a 49 cc pocket rocket at my dads, but i havent been able to get it working so im thinkn about stripn it for parts for either my metal work project (a pedal kart, that i want to be kick-a$$ so i get the top mark) or for a future go kart.......
only question is what parts should i strip off it, and also any ideas on why it isnt working (it doesnt start or spark, so havnt been able to get it to start)....... and yes i got it for free off a friend
Old 04-05-2011, 08:32 PM
karl's Avatar
karl karl is offline
Just get it running. A 50cc wont push a go-kart. Go on ebay and parts for those engines are dirt cheap. Like $5 for piston rings. Take a look before stripping it.
Old 04-05-2011, 08:39 PM
Quote:
thing is its a little old and the body is cracked etc, the main problem is im nearly 6 foot and a mini bike...... i dont fit on it lol
Old 04-05-2011, 08:44 PM
Doc Sprocket's Avatar
Mini bike, or pocket bike... There's a difference, 'round here, anyway...
Fix it and sell it.
Old 04-05-2011, 08:47 PM
known as a pocket rocket in aus......
they also call it a mini bike here, but most commonly referred to as a pocket rocket. there only worth like $50 anyway
Old 04-05-2011, 08:58 PM
robbie robbie is offline
If it's too small for you, turn it into a bigger bike. Cut the frame and insert pieces big enough so you can ride it.
  #7
Old 04-05-2011, 09:01 PM
Quote:
yer, but im rly into this pedal kart im making, and id love to get the highest mark, so far mines better than the teachers and i hav no experience with pedal karts or go karts.....
  #8
Old 04-05-2011, 09:28 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
I dont think any parts from a pedal kart are found on a pocket bike...
No spark? Space between the magneto and flywheel should be .010"..... you probably use metric in AUS though. Try using a credit card to space that gap.
Also, check the plug wire. Make sure its not cracked at the base. I had this happen once.
Check the spark plug. Make sure its not gunked. If it is, clean or replace.
Lastly, disconnect the kill wires from the coil. Sometimes the kill switch can be broken so this simplifys the problem and just narrows what the problem can be.
Can a go kart count as a metal-work project?
  #9
Old 04-06-2011, 01:14 AM
were not aloud to put an engine on it..... but i can make one minus the engine if i want, but wuldnt that be a bit hard?
Closed Thread
