  #21
Old 12-16-2014, 06:37 PM
zzirrgrizz zzirrgrizz is offline
Originally Posted by mental74 View Post
You can get 2 stroke 49cc Chinese engines for next to nothing & there are aftermarket parts all over eBay for them. As stated above, that 2hp motor you have is above 50cc. I think that you're more than double the cc you're able to run, so you're going to have to get a new one to comply with the law.
I know ): But I really hate buying those things ! They sound like weed whackers lol! But I may have no choice. I just really wanna be able to use this Briggs
  #22
Old 01-04-2015, 04:55 AM
Moedog07 Moedog07 is offline
Look up common hop ups for the flathead Briggs 5hp engines. Index the spark plug. You can mill the head at home and run a straight pipe for the exhaust but you may have to adjust the richness of the fuel mixture on the carb. Any changes in the exhaust may make the engine run lean.
The gear ratio may burn up the clutch in no time at all.
The Following User Says Thank You to Moedog07 For This Useful Post:
Poboy kartman (03-22-2015)
  #23
Old 03-22-2015, 08:19 PM
Bump bump bump...
  #24
Old 03-22-2015, 09:49 PM
Poboy kartman Poboy kartman is offline
Banned
HINT: Check out LensCrafters.....they might be able to help you out....
  #25
Old 03-23-2015, 09:25 PM
What do you mean? I'm confused
  #26
Old 03-23-2015, 09:38 PM
Banned
"Bump bump bump?"
Maybe some glasses could help you from continuing to do that.....and walk around stuff.....
  #27
Old 03-23-2015, 09:57 PM
"Bump bump bump?"
Maybe you didn't notice but I updated my original post and uploaded more photos. Which is why I bumped it because I wasn't sure if just "Editing" my first post would automatically do it for me.
And not sure what glasses or LensCrafters has to do with anything here
And I really don't get the "and walk around stuff" part? What are you trying to say?
  #28
Old 03-23-2015, 11:33 PM
mckutzy mckutzy is offline
They're pulling your chain....
Yes the acronym itself means Bring Up My(original) Post...
But, when someone simply writes bump bump bump.... It just sounds funny.... Like as if you didn't see it comming and it bumped you in the face....
Just saying...
  #29
Old 03-24-2015, 01:21 AM
landuse's Avatar
landuse landuse is offline
You are correct. Editing your post will not bring it up as a new post for people to see
  #30
Old 03-24-2015, 11:36 AM
Just saying...
Oooooh okay thanks man! I was so confused
