Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Forum
Old 03-13-2019, 10:15 PM
supermanotorious's Avatar
supermanotorious supermanotorious is offline
Winchmaster 5000
Default Internet speed and whatnot
As a start (before I launch off the rails in to the deep end) why does speedtest.net show drastically faster speeds than "internet speed test" by Google's partnership with Measurement Lab (M-Lab) on the exact same PC/router/modem/browser?!
www.phoenixwinch.com
www.facebook.com/wakeskatewinches www.youtube.com/user/phoenixwinch
Old 03-13-2019, 10:48 PM
Tpdingo Tpdingo is online now
Because speedtest shows you the speed you want to know. Its happier to live in a world of lies.
Old 03-13-2019, 10:53 PM
anickode's Avatar
anickode anickode is offline
Also depends on the server you're connecting to. Speed tests are done by timing data packet bursts back and forth. If the server is pressed for bandwidth, or only allocated a certain amount of bandwidth per connection, it can affect the outcome. Don't know if that's the case here, but it can make a difference.
There's also the Mbps vs MB/s (megabit vs megabyte) deal. Different units = same speed, different number. Again, don't know if that's the case, but it will make a big difference. 1MB/s = 8Mbps
"Well that would be a bomb."
