Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
  #81
Old 03-27-2011, 10:37 AM
studysession's Avatar
studysession studysession is offline
CNC Guy
Quote:
Originally Posted by jrmints1415 View Post
B.M. if you want a welder but dont have a lot of money or experience you should get this welder!
http://www.harborfreight.com/welding...der-98871.html
it comes with everything you need to start a mask, wire, and the welder of course. If you can use a hot glue gun then you can use this welder! I actually have one so i would know haha
I have that same welder. Using it to learn on making a bar stool racer and next will be a mini-chopper.
CNC Site - http://celticmachining.com
CNC Blog - http://cncinside.com
  #82
Old 03-27-2011, 03:14 PM
MK3roberts's Avatar
MK3roberts MK3roberts is offline
creater of the ____ kart.
OP, it seems like you waste a lot of your money with impulsive buys, not thinking things through.
cool bike though.......
  #83
Old 03-27-2011, 06:50 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
Quote:
thats my welder, and its great. i cant say anything bad about it.
not true, sometimes i almost think things through too much.
the engine from this bike is now in my kart. and the rest of it will be used in other builds.
its a good learning experience as well.
not to say i didnt get any riding from it though. i put about 5 hours on it.
  #84
Old 03-28-2011, 01:26 AM
FictitiousSpoon FictitiousSpoon is offline
Junior Member
Actually brazing can be stronger then welding in certain applications; the reason why is that when you're brazing the filler flows into the joint and coats a larger surface area then you could get while welding. So it would be a lousy method if you wanted to do a butt joint or fillet or whatever but it would work really well for something like a lap joint where you could only make a weld bead on two points whereas with brazing, if you do it right, you can make the filler flow between the two pieces of metal and you would get a bond covering the entire overlap. You can apply this to tubing by putting a metal dowel in the ends of the tubing you want to join. Or if you want to braze a piece of tubing perpendicular to another piece of tubing you can use steel bands. Both of these techniques can be seen in the Tom Thumb minibike. http://www.diygokarts.com/bike-plans/pocket-bike.html
Closed Thread
