Closed Thread
  #361
Old 01-12-2010, 07:53 PM
BriggsTwins's Avatar
BriggsTwins BriggsTwins is offline
PB blaster and let it soak!!! that will break it loose. be careful otherwise your gonna be drilling and retapping that hole
two is always better than one! -Twin Coalition-
  #362
Old 01-12-2010, 08:31 PM
Rotore Rotore is offline
Teh SPIK
I got them apart already took me 10mins. Btw what's the slide on it for?
"No one is going to open doors for you your whole life, sometimes you have to open the dor yourself." Eddy
  #363
Old 01-12-2010, 09:28 PM
which slide, the thick round one, or the flat one
  #364
Old 01-12-2010, 11:08 PM
Teh SPIK
Flat one?
  #365
Old 01-13-2010, 06:55 AM
modelengineer modelengineer is offline
Lord of the noise
I discovered that my twin has only been firing on one cylinder, so the vids really show a 250cc single... It's all good now though.
In the carby the round one is the butterfly, the flat one is a vacuum operated slide. AFAIK it's used instead of an accelerator pump, but instead of injecting more fuel, it stops the throttle being opened really quickly which would cause the engine to run lean.
Andrew
GS500F powered...
  #366
Old 01-13-2010, 09:13 AM
Teh SPIK
So its the slide opens with the vacuum created by the engine and draws it's own fuel instead of using a pump?
I see no point in using it now....
  #367
Old 01-13-2010, 09:16 AM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
From what i understand its just basically to make the throttle response very even and smooth, you will get better performance from a flatslide or even a roundslide, there just way to complicated IMO, why have a slide, butterfly, AND choke. Mikuni slide carbs just have a slide, they dont even have a choke.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
  #368
Old 01-13-2010, 10:20 AM
Teh SPIK
Oh ok I get where your going with that
  #369
Old 01-13-2010, 02:27 PM
Lord of the noise
My Mikuni's have a butterfly, a slide, and a choke but the choke is (I think) another fuel jet which opens. It's not another air restrictor.
Andrew
GS500F powered...
  #370
Old 01-13-2010, 02:32 PM
Pro Junk Collector
You must have CV carbs if they have a butterfly and a slide. I'm talking about plain slide carbs, which used a cable operated slide and have no choke, just a fuel enrichment circuit (which is basically another jet like you said that is opened when you pull the choke lever/cable).
  #371
Old 01-13-2010, 04:58 PM
Teh SPIK
Shoul I keep or remove the govener on the twin?
  #372
Old 01-13-2010, 08:16 PM
keep it, do you really need the rpms? when you can make it work with a governed speed
  #373
Old 01-13-2010, 09:43 PM
Teh SPIK
I don't think I still have the springs or linkages so yea
  #374
Old 01-14-2010, 01:16 AM
then no worries
  #375
Old 01-14-2010, 07:56 AM
Teh SPIK
Lmao i'm really about to drop a grand on this engine
  #376
Old 01-15-2010, 11:12 AM
better get it a nice home then
  #377
Old 01-15-2010, 11:42 AM
Teh SPIK
It's moré of a long term build now
  #378
Old 01-16-2010, 10:47 AM
just like me.... got a welder though, that was my milestone to move on with the build
Closed Thread
