Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 03-04-2018, 03:58 PM
scatteredsun scatteredsun is offline
Default Oops, only measured once. Sprocket too big
So I messed up. I got a 60T sprocket but there's too little room between the sprocket and a swingarm support bar.
I have two options as I see it.
1. I take the bearing flanges off and get them welded to the end of the arms. This should give me a good 2 inches or more. It would also improve the clearance for the engine and torque converter and make i tall fit much nicer.The problem is it messes with my brake mounting. I'll have to figure out how to get it all mounted in a different position.
2. I change the gearing. I could go to a 54t on the axle and 9t on the torque converter. I would still have a 6:1 but I would gain almost an inch clearance on the axle. The only unknown to me is if the 40 series TC can have a 9t sprocket on it. I'll do some digging and figure that one out.
Both have their benefits. 1 fixes a couple problems but introduces a new one and will be more expensive. 2 I think will be cheaper.
Old 03-04-2018, 04:40 PM
mckutzy mckutzy is offline
Switch to a #35 chain on both... itll be smaller...
The Following User Says Thank You to mckutzy For This Useful Post:
bob58o (03-04-2018)
Old 03-04-2018, 05:19 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Do you have a 5/8" Jackshaft or a 3/4" Jackshaft???
Like ^^^^ said.
You can get a 3/4" bore #35 10T sprocket.
You can get a 60T #35 Rear Sprocket.
You will gain over an inch of clearance from sprocket to frame.
You will loose chain strength.
If you have a 5/8" Jackshaft you have more options.
The Following User Says Thank You to bob58o For This Useful Post:
mckutzy (03-05-2018)
Old 03-04-2018, 07:44 PM
I'm getting a 40 series TC. Looks like its a 5/8" jackshaft.
I'm leaning more towards doing a 9t and 54t. The 54t sprocket is nearly an inch narrower.
I may even bump up to 20" tires from the 18" on there now. That'll give a couple more inches of ground clearance. Are 60t mostly used for racing? There's very little ground clearance with the giant sprocket. I can see it getting caught up in mud or logs.
I may wait until after I get the TC just so I can get a more accurate picture of how much room I'll have.
Old 03-04-2018, 10:22 PM
bob58o's Avatar
A 60T #40 sprocket is what? 9.5"? Your 18" Tires should give you over 4" ground clearance.
A 54T sprocket is about an inch smaller, but you only gain 1/2 clearance.
Old 03-04-2018, 11:49 PM
Ebrownie's Avatar
Ebrownie Ebrownie is offline
If it was me and I wanted to save money I would just cut that bar off and reweld it up forward 1/2”. But from the sounds of it you don’t have a welder?
  #7
Old 03-05-2018, 12:01 AM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
I'd cut the bearings off and move them back to gain the space. You'll be pushing your gearing with 20" tires. A #35 60 tooth and a #40 60 tooth are pretty different diameter wise. Even a 72tooth is about a good inch smaller in diameter.
  #8
Old 03-05-2018, 08:22 AM
TT540 TT540 is offline
Newb
Quote:
Originally Posted by Ebrownie View Post
If it was me and I wanted to save money I would just cut that bar off and reweld it up forward 1/2Ē. But from the sounds of it you donít have a welder?
I'm with this guy. When something gets in my way, I move it.
You could just clearance/cut away what you need to fit the chain. Then attach a 5" long square tube (1"x1") piece on top of the notched section to give it the support it once had.
This is assuming the jackshaft is toward the rear.
  #9
Old 03-05-2018, 11:29 AM
Ok, all great points
No, I don't weld. Tempted to just buy one and learn on my own but I don't have a lot of time to play.
I needed to take the whole unit in to a shop to get the engine mount plate welded on. I'll have them cut the bearing flanges off and weld them on at the end. That will give me more than enough clearance and will hopefully help the TC fit better. I'll also have to figure out where/how to mount the brake caliper.
How much stronger is #41 vs #35? I'm not racing but I do plan on hauling a small trailer and i got lots of sticky mud.
  #10
Old 03-05-2018, 12:03 PM
Newb
#41 has a tensile strength of 2,000 Lbs
#35 has a tensile of 2,100 Lbs
So not much.
I like your plan to give yourself some room for the TC and for planning on a disc brake. good luck!
If you are having someone else weld it, save yourself some time and money by grinding away and cleaning the welding areas well. As soon as you get it back, wire brush it some and paint it with a primer before it rusts. If they weld a lot, it will heat the metal and maybe ruin some of the nearby paint, so keep an eye out for that.
Oh, and invest in some C clamps or vise grips. Use them to hold your engine plate in place where you want it. The place you have doing the welding might not care about "square" and getting the engine orientation exact. Same goes for those rear carriers... don't want to have to turn left to go straight! lol.
The Following User Says Thank You to TT540 For This Useful Post:
scatteredsun (03-05-2018)
  #11
Old 03-05-2018, 12:12 PM
If you move the axle back, you'll need the brake disc/caliper setup, all the associated parts for the rear end, as the brake bracket needs to be relocated aswell... Getting all that aligned to work well is going to cost you money at a shop...
For the most part a better bet would be get #35 chain, and bolt on a motor plate with risers if needed. No welding and you can do this all yourself.
  #12
Old 03-05-2018, 12:53 PM
Good call on clamping the plate. I was just going mark it with a marker but that's way better.
---------- Post added at 10:53 AM ---------- Previous post was at 10:50 AM ----------
hm, bolt on motor plate eh? Haven't seen those. Risers are going to be a problem. As it is, I only have 1.5" clearance between the top of the engine and the bottom of my frame.
I can see a problem if the chain has any sort of angle towards the engine. If the TC sprockets sits above or even slightly to the rear of the axle sprocket I'm golden.
  #13
Old 03-05-2018, 02:31 PM
hm, this 60t #35 manco sprocket is only 7 1/4". That should definitely be enough room even if the TC sprocket ends up in a weird spot.
---------- Post added at 12:31 PM ---------- Previous post was at 12:23 PM ----------
crap, I'll have to get a 10t #35 sprocket for the jackshaft
  #14
Old 03-05-2018, 07:47 PM
A bolt on motor plate is something your going to make custom to fit the space available and where ever a bolt/U-bolt mounting point is adequately positioned.
3/16" would do, 1/4" thick might be better....
  #15
Old 03-06-2018, 04:56 PM
Oh sure that makes sense. The only mount plate I saw had 90* lips on the edges. It's not going to fit anywhere in the space I currently have so a custom plate is going to have to do. I was just going to have a shop weld on a 1/4" plate where I need it and then cut the slots in.
I'm going to wait until I have the TC on before making any final decisions but I do think going to #35 chain will be the cheapest option. I even have the hub for the sprocket already.
  #16
Old 03-21-2018, 12:16 PM
So it looks like a 10T #35 sprocket isn't going to be strong enough so I'd have to bump up to a 12T and 72T. That only gives me an extra .5" clearance on the axle sprocket. (the 72T #35 is 8.75" compared to 9.75")
I'm still going to wait until I get the TC bolted on to the engine before deciding but I'm beginning to think just notching a chain path into that bar isn't a bad idea.
Closed Thread
