Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 08-30-2014, 03:45 PM
ethospace ethospace is offline
Default Ok so the wife wanted a baja mini bike also
SO I went to my fav site ( Craigslist ) LOL and bought another bike
in better condition than my first but i cant seem to keep it running. I can get it to start if I spray some starter fluid in it but then it dies. I took the carb off and cleaned it and soaked it in some gas for a few hours before cleaning it. But I still cant seem to keep it running. any ideas? i'm stumped. ( doesn't take much) LOL
Old 08-30-2014, 03:47 PM
BirdFanatic BirdFanatic is offline
magneto spark plug did u clean the tiny holes with a wire from a cord or wire brush carb cleaner does not always get everything
Old 08-30-2014, 03:55 PM
Poboy kartman Poboy kartman is offline
Banned
No magneto....no spark plug problem. ...carb is still dirty...as Birdfanatic said. ...you need to poke the small holes. .....
EDIT:....And get some carb cleaner or boil in lemon juice. ...soaking in gas does nothing. ....
The Following User Says Thank You to Poboy kartman For This Useful Post:
ethospace (08-30-2014)
Old 08-30-2014, 04:25 PM
ML-TOYS's Avatar
ML-TOYS ML-TOYS is offline
Ok stupid questions. Is the petcock open ? Is gas getting to carb ?
Old 08-30-2014, 04:26 PM
wel I pulled the other carb off of the other one and tried it to confirm it is a carb prob. So I guess Im off to go buy some lemon juice. BTW yes I swapped out the plugs in both. ( they needed it )
Old 08-30-2014, 06:04 PM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
It's always good to have extra "known to be working" parts laying around. I got spare clone carbs,and pz19 carbs for atv/dirt bike engines up to 110cc. I have 1 spare pz26 for bigger engines, 125cc-200cc, but it's jet is a hair small for proper function on a 200cc. (it will still crank and run one, you just won't get the best performance out of it.... Like with a pz28 or pz30..... )
  #7
Old 08-30-2014, 09:09 PM
So i did the whole boil it in lemon juice thing, cleaned it and put it back together. Still no dice. Since I am press for time ( I am taking them on a camping trip in a few weeks) Has anybody had any experience good or bad on these 20.00 carb from ebay vs the 46.00 one from ombwarehouse? I saw a rebuild kit for one on ebay for 20.00 but it the 20.00 car works well why waist the time. Just a thought. Thanks for all the input today.
  #8
Old 08-30-2014, 09:30 PM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
Quote:
I bought a $20 clone carb from ebaybefore and no problem
  #9
Old 08-30-2014, 10:35 PM
mckutzy mckutzy is offline
Whats in the gas tank, is there any crap floating about at the bottom?
Whats the motor?
The Following 3 Users Say Thank You to mckutzy For This Useful Post:
2SlickNick (08-31-2014), KartFab (08-30-2014), OzFab (08-31-2014)
  #10
Old 08-31-2014, 04:51 AM
its the standard engine in it. nothing in the tank. i drained it when i swapped the carbs out.
  #11
Old 08-31-2014, 07:57 AM
zbuck zbuck is offline
Standard type engine, does not get it. Like the man ask, what engine. Therefore we will know what type carb you are working on. An then we can probally help you you.
The Following 2 Users Say Thank You to zbuck For This Useful Post:
2SlickNick (08-31-2014), mckutzy (08-31-2014)
  #12
Old 08-31-2014, 08:41 AM
2SlickNick's Avatar
Baja makes several types of mini bikes....
The Following User Says Thank You to 2SlickNick For This Useful Post:
  #13
Old 08-31-2014, 10:05 AM
ML-TOYS's Avatar
Motor type and even pics of the carb setup can help
The Following User Says Thank You to ML-TOYS For This Useful Post:
  #14
Old 08-31-2014, 10:17 AM
KartFab's Avatar
KartFab KartFab is offline
Pics are great. Older style baja heat/green baja warrior use the JF200 (honda clone).
http://www.purplewave.com/cgi-bin/mn...gi?081213/6514
The newer ones use what I believe to be a homelite engine?
http://www.monsterscooterparts.com/2...ke-engine.html
The Following User Says Thank You to KartFab For This Useful Post:
  #15
Old 08-31-2014, 12:45 PM
firemanjim's Avatar
If ALL you did was soak in lemon juice, then you failed.
You need to take out the main jet and clean it. The emulsion tube also. The idle jet too.... Just soaking it ain't gonna work... You need to be able to blow through all the jets to make sure they're clear. And the fuel circuits.... Fuel in..... Fuel out......
  #16
Old 08-31-2014, 12:51 PM
Ok thanks I didnt know there was more than one motor type. I bought 2 bikes at different times and they were the same motor so I assumed....... that what i get for assuming .... my bad.
http://www.purplewave.com/cgi-bin/mn...gi?081213/6514 is the type that I have.
I'm thinking about ordering this carb http://www.ebay.com/itm/MINI-BAJA-HE...item23342e32b3
SO I can stop assuming, how can I figure out if I have the mb165 or the mb200 ? for ordering a carb. on the omb site there are 2 different part numbers 1- for the 165 and 1- for the 200? So confused.
Honestly jim all I did was boil it in 100% lemon juice. Then rinse it out with water and dried it with the air compressor. I honestly dont have the time to take it apart. See Im a truck driver and only home 3-4 days a month so my todo list long and hairy when I get home. So I rather just order a new one and swap it out. Because the next time I come home we are leaving on our fall camping trip as soon as I get home. and I can change the carb out at the camp ground.
  #17
Old 08-31-2014, 01:04 PM
2SlickNick's Avatar
Link to pic does notwork. Here.....http://www.bajamotorsports.com/categories/minibikes
  #18
Old 09-03-2014, 08:52 PM
MadMechanic01's Avatar
MadMechanic01 MadMechanic01 is offline
Junior Member
It only takes about 5 minutes to break down a carb and clean it properly get some torch tip cleaners I find they work the best and clean out every jet problem solved.
. Sent from my iPhone using Tapatalk
  #19
Old 09-05-2014, 05:30 AM
You have to be careful when using torch cleaners. You can over size the jets in a hurry. Best bet is to use a fine wire.
  #20
Old 09-05-2014, 12:29 PM
well for time constraints ( and I was already there ) I just picked up a harbor freight engine and slapped it in. runs great. Now the only prob I have is like others in this situation. no headlights. I will figure something out.
The Following User Says Thank You to ethospace For This Useful Post:
apekillman (09-11-2014)
Closed Thread
