Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
  #41
Old 04-20-2014, 12:19 PM
DaiSan76's Avatar
DaiSan76 DaiSan76 is offline
I went from a .86 to a .95, and it went from being too lean to being at little too rich, and it cut out at high rpm. I changed from the crappy chinese plug to an NGK, and now it runs like a champ.
http://www.diygokarts.com/vb/showthread.php?t=12557
http://www.davisphotodesign.com/
  #42
Old 04-20-2014, 01:11 PM
88nightrider's Avatar
88nightrider 88nightrider is offline
Quote:
Aside from getting a better brand plug (like NGK), I would also recommend (especially to the smaller two stroke engines) to get a long reach spark plug.
Stock type:
Long reach:
  #43
Old 04-20-2014, 05:25 PM
DaiSan76's Avatar
What I bought looks longer than that. After it got it good and warmed up, and took the throttle limiter out, it seems like it is back to lean on the top end again. I don't know if Fabroman is enjoying this semi-related banter in his thread or not. I do have my own thread on this machine in Off Topic fun.
  #44
Old 04-20-2014, 05:38 PM
One question: Are you talking about the threaded part being longer?
Edit:
Anyways, the quad you got, and the pocketbike probably have about 75cc of difference in engine size.
Your's being a 4 stroke, while this is a 2 stroke.
In other words quite different engines
  #45
Old 04-20-2014, 09:44 PM
DaiSan76's Avatar
Quote:
Edit:
He also has a 110cc quad, which is a 4 stroke, virtually the same motor, and also being discussed in this thread.
  #46
Old 04-21-2014, 07:48 PM
OzFab's Avatar
OzFab OzFab is offline
It's all good & relavent info so, please continue...
I haven't had time to do anything with the pocketbike but, the weird thing is, it was fine a week ago...
  #47
Old 04-21-2014, 07:57 PM
Quote:
Was the fuel tank on the pb used much before you got it?
  #48
Old 04-23-2014, 07:12 PM
OzFab's Avatar
I have no idea but, I made sure I cleaned it thoroughly & fitted a new fuel line & filter. I need to get a new tank because this one only has a makeshift cap; it works but, it doesn't look great...
Why do you ask?
  #49
Old 04-23-2014, 08:24 PM
Why do you ask?
When the fuel tanks are new they are known to have plastic shavings in them that can clog up the carb.
Regarding the makeshift fuel cap. Have you tried to run the bike without it?
If the cap is not letting in enought air you end up with an vaccum when the engine is running.
Just a thought
The Following User Says Thank You to 88nightrider For This Useful Post:
OzFab (04-23-2014)
  #50
Old 04-23-2014, 11:22 PM
OzFab's Avatar
Just a thought
A very good one, I never even considered that...
  #51
Old 04-24-2014, 09:37 AM
Quite common on these pocketbikes. Especially when modding them. I had to drill larger went holes in my fuel cap. More power and RPM's equals more fuel and air to enter the engine. So more air must come in through the fuel tank vent to not generate a vaccum that would starve the engien of fuel
  #52
Old 04-26-2014, 09:06 PM
DaiSan76's Avatar
Do you know which carb you have on your quad Fabroman? I have a pz20, and I can't get the thing to run well both on the high and low end. Maybe it's just because I suck at Tuning carbs.
  #53
Old 04-27-2014, 08:15 PM
OzFab's Avatar
No idea, I'll check it out & get back to you...
In the meantime...
Closed Thread
