Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
  #21
Old 11-10-2008, 03:24 AM
mcbob mcbob is offline
Junior Member
Yea but most Victa 125 and 160cc engines can be rebuilt very cheaply especially out here in Australia and there's millions of them around for spares most of the older briggs and tecumseh's are stuffed bore wise anyway just wait till your Suzuki needs overhaul and you'll see what i mean.
I ran a small engine overhaul shop for quite a few years and experiance i feel counts.
Speed is not everything Russ2251.
Mc Bob
  #22
Old 11-10-2008, 03:32 AM
Junior Member
Quote:
Originally Posted by mat93 View Post
how do u make the throttle. im having trouble. does no clutch affect the engine negativly??
You need either the G3 carby or an Amal that the Delteks and Decksons used and if using the G3 carb you can remove the govenor vane and braze an arm on the throttle shaft which you can atach the throttle cable too.
Mc Bob.
  #23
Old 11-10-2008, 05:27 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
To me it's the only thing.
My Suzuki?
Those that can...do. Those that can't...buy a predator.
  #24
Old 12-26-2008, 12:07 AM
waynek56 waynek56 is offline
Junior Member
Default no clutch??
Quote:
Originally Posted by mcbob View Post
The clutch on the Victa's is a tapered shaft that requires no key it's an interferance fit that snugs up tight on the taper then as the outer sleeve is tightened it retains the clutch simple and effective.
There no negativty here just simple engineering these engines run at between 3600 rpm and with the correct amal carby will run higher mine run around the 4500 rpm.
These are a far better engine than the Lawnboy will ever be.
Mc Bob.
  #25
Old 12-26-2008, 03:07 AM
modelengineer modelengineer is offline
Lord of the noise
I think he was referring to MY Suzuki mower.
I still think it's one of the best 2-stroke mower engines ever made.
Andrew
GS500F powered...
  #26
Old 12-26-2008, 05:59 AM
Russ2251's Avatar
I could not agree more. They (Suzuki) have a projected lifespan of about 5 or 6 times that of an average mower engine.
I take issue with the following statement:
Quote:
These (Victa)are a far better engine than the Lawnboy will ever be.
Based on what? I question his 'experience'.
Lawn-Boys were considered among the best engines on the planet. So called 'global warming' is the only thing that could (and did) kill them.
As far as performance on a kart or mini bike goes, it's been stated that "just simple engineering these (Victa) engines run at between 3600 rpm and with the correct amal carby will run higher mine run around the 4500 rpm."
I get 6000 rpm or better with a $30 carb and no mods other than slightly altered compression ratio and straight exhaust.
Also, do a Yahoo search on Victa parts. Then do a search on Lawn-Boy parts.
See the problem? It's easier to get parts for a Yugo.
No wonder they never made their way to the states.
At one time I wanted to get my hands on a Victa. Now I know it's the last thing I want.
  #27
Old 12-26-2008, 08:20 PM
rock-star-4life@live.com rock-star-4life@live.com is offline
how are you suppost to stop when you have no clutch!!!!!
  #28
Old 12-26-2008, 08:27 PM
Russ2251's Avatar
Kill ignition or just stall it out by applying brake.
  #29
Old 12-26-2008, 10:22 PM
jr dragster T's Avatar
jr dragster T jr dragster T is offline
Yeah with a direct drive setup it doesnt take long after letting off the throttle to slow down. Well assume the engine has reasonable compression. What where to happen if the engine sudden decided to wedge its rod? Eeeek could get nasty.
  #30
Old 12-27-2008, 03:29 PM
sayre315 sayre315 is offline
Rupp enduro
Mr. Russ i couldnt agree more with your statment about LB's
down here in Oklahoma i try to get every single lawn boy i can and as fast as i can because those things sell quickly and in the right hands they sell for a pretty goob price
i buy them for cheap, fix 'em up and usally they sell for anywhere from $50-$120 within the 2nd to 3rd day, somtimes even on the 1st
and i make a fortune doing so
  #31
Old 12-27-2008, 03:51 PM
Russ2251's Avatar
Quote:
...and usally they sell for anywhere from $50-$120...
I think you should split profits with me!!!
  #32
Old 12-27-2008, 06:05 PM
Rupp enduro
lol with all the hel pthat you've give'n me i otta give it all to you
  #33
Old 12-27-2008, 06:26 PM
ZnsaneRyder's Avatar
ZnsaneRyder ZnsaneRyder is offline
Crazy Guy on a Bicycle
Why have NO clutch, when it's not much more effort to install one? It's nice just to throttle-N-go.
If you are on a tight budget get the Max Torque or Comet, they are $30 or less.
If you want the BEST reliability, and HP handling, and easiest-to-work-on clutch, then get a Hilliard Extreme-Duty. I'm VERY pleased with mine.
Get an extra bronze bushing to ensure the life of your clutch.
Max Torque-
http://www.mfgsupply.com/m/c/4-455.html?
Comet-
http://www.mfgsupply.com/m/c/209760A..html?
Hilliard Extreme-Duty-
http://www.mfgsupply.com/m/c/H3435.html?
New Kart Blue & Purple ThunderKart Frame 1-Wheel Peel, 7HP Predator 212cc Engine, 10T Hilliard Clutch, 54T Sprocket, 15x6x6 Rear Tires, 10x4.10x3.50 Front Tires
  #34
Old 12-27-2008, 06:29 PM
Russ2251's Avatar
Some folks just don't want one. It's a different driving experience to be sure.
  #35
Old 12-27-2008, 06:49 PM
Rupp enduro
yes, it is COMPLETELY differant
  #36
Old 12-27-2008, 07:32 PM
And they carry sprockets for oddball crankshaft's. Unlike clutches on most case's.
  #37
Old 12-27-2008, 09:27 PM
go kart mozart's Avatar
go kart mozart go kart mozart is offline
yeah clutchless stuff = death trap usually
"Fords are for sissies!, real men wear BOW TIES" - Chevrolet
  #38
Old 12-27-2008, 09:38 PM
Russ2251's Avatar
Not at all. Just different.
  #39
Old 12-28-2008, 02:05 AM
BradenM BradenM is offline
Etre Et Durer.
The reason he is talking about using direct drive on a victa is due to the expense involved in mounting a clutch. Victa's have threaded driveshafts, so if you don't have access to a lathe, or friends that can do it for you, it will set you back around $70 AU to get a custom sleve made up so you can mount a clutch. Then add the price of a new carby, which is 100% required, then the custom manifold to make it fit, then a clutch, chain and sprocket, and you have spent at least $170 AU. Add in misc stuff like gasket's and you're talking $200. You could have had a 6.5 horse clone off ebay, and a clutch, chain and sprocket for a tiny bit more. It's really not feasible to use a Victa unless your spending someone else's money, or have a large amount of your own.
Quote:
Originally Posted by gokartcrazy View Post
omg i almost poopied my man thong i didnt know my brother wore thongs too
  #40
Old 12-28-2008, 07:11 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Quote:
Direct drive, dirt track KT-100 racing used to be really popular. Only dangerous part is push starting it without a helper and jumping in the running cart while feathering the throttle so it wont stall out.
Closed Thread
