Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
  #21
Old 08-27-2012, 06:11 PM
gvfc2 gvfc2 is offline
wishing i was living
let me know how it works for you. i cant make it yet as i dont have any parts for it
  #22
Old 08-27-2012, 07:29 PM
Bobby's Avatar
Bobby Bobby is offline
im still gathering parts too
Future Cart-338cc Grey Hound Engine, 20" Mud Tires, 6 Speed Homemade Transmission
  #23
Old 08-27-2012, 08:24 PM
Bobby's Avatar
does anybody have any ideas for putting the sprocket onto the rear axle its a plastic rim
  #24
Old 08-28-2012, 01:33 AM
landuse's Avatar
landuse landuse is online now
A 6HP is way too much power. You are going to be tearing the scooter to pieces.
This is what I mean about the scooter being torn to pieces. There is too much torque on a 6HP. You want to gear at 5:1. That is not low, but it is low enough to produce too much torque for plastic to hold up for long
I know fixing things is part of the whole DIY thing, but if you are going to be fixing things every time you ride the scooter, it is going to get old really fast.
With that being said, I would also like to see how this turns out. You might even prove us all wrong
  #25
Old 08-28-2012, 02:52 AM
id suggest getting a metal rim instead of plastic. or instead of chain drive friction drive. IMO chain would be way better
  #26
Old 08-28-2012, 05:03 AM
OzFab's Avatar
OzFab OzFab is offline
6hp on that, are you completely nuts?
I'm building a smaller version with a 25cc line trimmer engine. Not only is it way too much power, your balance will be all over the place
  #27
Old 08-28-2012, 06:10 AM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
The problems (and expense) will mount as time goes by.
I envision some serious issues with stability/safety.
Those that can...do. Those that can't...buy a predator.
  #28
Old 08-28-2012, 07:14 AM
Bobby's Avatar
Quote:
do you know where i can get one
  #29
Old 08-28-2012, 07:17 AM
Bobby's Avatar
Quote:
how do you think motorcycles stay up the faster they go the less the rider has to try and keep the bike up. yes i realize that the weight is centered on a bike but i can move the engine as close to center as possible on the scooter
  #30
Old 08-28-2012, 07:29 AM
landuse's Avatar
Quote:
Originally Posted by Bobby View Post
.....i can move the engine as close to center as possible on the scooter
Where will you stand?
  #31
Old 08-28-2012, 08:39 AM
Bobby's Avatar
no i'll still stand in the middle i meant put the engine in the center over the rear tire not in the middle of the scooter
  #32
Old 08-28-2012, 09:38 AM
OzFab's Avatar
A standard 12" bicycle wheel will work & it will have a sprocket if you find a rear
Hey, I'm not saying "don't do it", go for it. If it works for you, great
  #33
Old 08-28-2012, 10:36 AM
Swabbster's Avatar
Swabbster Swabbster is offline
look around for a 3hp briggs, i used a 3hp briggs tiller engine on a gas scooter frame, i removed the old engine and mounts welded custom mounts for the 3hp briggs and made side to side slots with my angle grinder to aline the chain, went good up all hills went about 40kph, i had a 11t clutch and a 72t sprocket running a 10 inch trolley tire, and those scooters are not good for building a gas scooter, the tubing is really thin and is hard to weld without melting through, frame can buckle easy, with 6hp you should just build a mini bike, it took me 2 days to get my mini bike built and driving, http://www.diygokarts.com/vb/showthread.php?t=13883
http://www.youtube.com/user/swabbster3?feature=mhee
  #34
Old 08-28-2012, 10:45 AM
Bobby's Avatar
fabroman what type of rear are you talking about for the tire.
swabbster i already had the 6HP thats why im using it, i orginally was going to build a mini bike http://www.diygokarts.com/vb/showthread.php?t=18007
but i decided if it was a scooter i could ride it to school and other places
  #35
Old 08-28-2012, 02:08 PM
i kids bike usually has 12 inch tires. if you can find a rear tire from one it will already have a sprocket on it
The Following User Says Thank You to gvfc2 For This Useful Post:
OzFab (08-28-2012)
  #36
Old 08-28-2012, 03:23 PM
Bobby's Avatar
i found a tire i had a little kids bike in my backyard and it does already have a sprocket
  #37
Old 08-28-2012, 03:24 PM
thats good. but chances are you are going to have to put a bigger sprocket on it
  #38
Old 08-28-2012, 06:14 PM
Bobby's Avatar
i would but then i have to take the sprocket on it now off. it is currently 16T +/- 2T
  #39
Old 08-28-2012, 06:15 PM
what size chain does it take? im guessing since its a bike it would take 421 IIRC. and that would snap from the torque of the engine
but it might be a number 40. standard for modern bikes. just measure the pitch of the teeth.
  #40
Old 08-28-2012, 06:49 PM
Bobby's Avatar
its anything but modern it like from '01
Closed Thread
