#41
Welds look pretty strong, good job.
Slag |
#42
Really o.O
Well, I removed the weedeater engine. The whole frame slowly bent while it was sitting (...), so when I started it, the chain slipped and jammed a couple of things. Didn't break anything though. Soo... I've decided to buy those 49cc "Clones" on eBay. Problem is, is the sprocket teeth the right pitch? Was wondering if anyone could tell me? Doesn't look like that tiny sprocket on the minibike... |
#43
My sons modded half-fairing cag.
![]() With custom pipe, I welded (first time with sheet metal) ![]() |
#44
Hey im wondering, how well did that work? Im thinking about making one for my KD100
For some there is therapy...For me there is motorcycles... |
#45
Walter - That looks GREAT!
I finishing up the welding on the frame. Tomorrow I'll hopefully have it together. |
#46
that is quite the pocket bike.
#47
that is a sweet pocket rocket!!
#48
I would assume its 8mm on the 49cc engines. #25 is smaller 1/4" pitch.
#49
On the exhaust pipe we didnt make from scratch - we added the blue section (making it longer than the stock pipe) moved the front cone forward and rewelded everything. Supposed to add more mid range power.
That pocket bike is always shaking itself apart - its a battle to keep all the hardware tight even with Loctite Last edited by Walter Keller; 08-07-2008 at 11:04 AM. Reason: another thought |
#50
realy?
#51
The cylinder bolts stripped out from the vibes even with loctite - you have to always be checking the bolts for tightness.
#52
try some green loctite, never come apart again, even if you want it too.
#53
I have the Green - its glue - it works great as long as you dont plan on removing anything ever.
#54
#55
![]() Quote:
![]() "With our gangster sticker; Boost. Gangster." ![]() Sorry don't mean to laugh, but it's funny!
"At the enrichment center we believe that if at first you don't succeed, you fail." GLaDOS - Portal |
#56
HEY
![]() Well, it seems we did weld it at the bottom, but it ah... was still too weak ![]() |
#57
Update if ne' one cares, Briggs 3HP carburetor. Cleaned it out with acetone, heat gunned it, cleaned out every lil' hole, cleaned out tank, also heated till dry, put gas in, choked, 3 pulls, started. Died. Unchoked, first pull.
Amazing. I never knew this carburetor could suck gas that fast! EDIT - With this carburetor, it revs ALOT higher. And I don't have to fill the tank every run ![]() Gained at LEAST 5-10MPH from this carburetor swap. |
#58
Theres only 10 holes in a briggs carb and thats counting the intake hole itself!
#59
![]() Quote:
![]() Thanks for the useful post Kenny! |
#60
Thread Tools | |
Display Modes | |
